Forest River Forums
Sunline User Photos
Old 09-11-2011, 04:31 PM   #1
Lightbulb What plumbing mods are "must haves"?
Upgraded from a PUP to a Roo. So, this is our first camper with plumbing (the sink in the PUP was never used). I'm primarily concerned about freshwater mods that are useful when it is time to winterize.
Suggestions and/or photo links would be much appreaciated.
TV: 2008 Ford Expy
Camper: 2012 Rockwood Roo 233S
BackInAction is offline   Reply With Quote
Old 09-12-2011, 05:48 AM   #2
miatared's Avatar
Well I would recommend a pump winterization/converter kit.
Your Roo already has a bypass valve for the water heater - this prevents the heater from filling up with the pink stuff (antifreeze)
It allows using the pump to pull the 'pink stuff' from the jug, through the plumbing apparatus (I always wanted to use this word... yipee)
Here is what it looks like:
Camco Mfg Inc - Pump Converter Winterizer Kit - Winterizing - Camping World
Money well spent.
Still in denial, I am looking at ways to cancel winter this year...
Denis
2011 Flagstaff Shamrock 19 aka Sham Wow
2009 Toyota Highlander Sport
miatared is offline   Reply With Quote
Old 09-12-2011, 06:13 AM   #3
If you have a compressor it will be time to use it. Fom me I used my second compressor hose and cutted the hose at the end to fit a garden hose attached with a jubilee clamp. Just insert the hose like you attache the garden hose for your camping. Adjust the pressure on the compressor to aprx 60 psi and keep your faucets closed until the compressor stop. Open all faucets one at a time for severals times until there is no more water in the lines.. Dont forget to remove the filter cartridge at the end and empty the plastic bowl. This bowl will not empty even if you pressurise the lines with air. When it is all done just add aprx 8 ounces of plumbing antifreeze in all the water traps. Leave all faucets opened at the end. Dont forget to bleed the 2 drain lines also under the trailers with pressure from your compressor. These 2 drains are the drains valves for the lowest point of the trailer. Remove the water heater drain plug fo the winter and at the same time check the anode for the next season. Like this you will be okay for the winter. I have done severals trailers this way because at the camground where I was I was doing most of the seasonals for winter preparation. Good luck PS> you just need aprx less than 2 gallons for this job. remark: at the end it is a must to disconnect the hose from your freshwater that go to the shur flow pump and dip this hose in a gallon of antifreeze. Pump half a gallon while you open the faucets to winterrize the pump. It is very important if you have used the pump during the season. After just reconnect the hose to your tank.
capucine is offline   Reply With Quote
Old 09-12-2011, 07:25 AM   #4
To DOs:
  1. Purchase/install the "Pump Converter winterizing kit".
  2. My output pressure control valve broke off my compressor some time ago. Guess I need to get that replaced.
  3. But a couple of gallons of the pink RV Antifreeze.
I think I might have to winterize twice this year as we have a trip over Halloween, but plan on going to the Smokies over Thanksgiving. 90% of the time I could probably wait until after the Thanksgiving trip, but every once in a while in Ohio, it actually gets cold (25F over night) before Thanksgiving.
TV: 2008 Ford Expy
Old 09-12-2011, 08:00 AM   #5
Also before you pump in the anti-freeze remove the filter housing and place a same size Pepsi bottle with lid attached inside where the element was located,saves anti-freeze and you dont have to buy a filter bypass kit. Youroo!!
Old 09-12-2011, 08:31 AM   #6
Great idea.
Though I think if I use the compressor to blow air out of the lines. Then I only need to fill the pump housing with antifreeze. So, once I see anitfreeze enter the filter's housing, I can stop.
Correct?
Does the shower have a trap? Or is it a straight pipe to the grey water tank?
Does everyone leave the plug out of their hot water tank over the winter? Or do you put it back in once you have it completely drained?
TV: 2008 Ford Expy
Old 09-12-2011, 06:55 PM   #7
miatared's Avatar
All sinks and shower have p-traps, so, yes you need to pour some antifreeze in all of them - 1 cup is OK.
Do not forget the exterior shower and the Inlet city water connection too.
Once the water heater is empty, put the anode rod back in - well that is what I do.
Re: Hallowen, I would winterize only after - it should not be that cold prior to that, or could it ??
Denis
Old 09-12-2011, 08:54 PM   #8
I'll have to winterize twice in 4 weeks, once after Halloween and again ~4 weeks later when we return from our Thanksgiving trip.
TV: 2008 Ford Expy
Old 09-13-2011, 07:44 PM   #9
flyrotor's Avatar
The air compressor to blow out the lines is great, especially if you are winterizing more than once during the cold season, only takes about 10 minutes to completely winterize, saves a bunch on antifreeze. We usually go early in the season and winterize several times in the spring and this works well.
2011 Dodge 2500 CTD, Crew Cab, 169" WB, 6-speed man
2008 FR Wildwood 23 BHLE
Nights camped in 2011:20
Nights camped in 2010: 21
flyrotor is offline   Reply With Quote
Old 09-13-2011, 08:41 PM   #10
I still have to use antifreeze to protect the pump and fill the traps, correct?
I looked at the $2 blow-out plugs city water input and to your compressor. What sort of fitting do I need at the end of my compressor hose to connect (and stay) on the blow-out plug?
TV: 2008 Ford Expy
» Online Users: 522
75 members and 447 guests
02 rockwood, 2007Rockwood2601, 4bnabird, 4Jeeperz, 64c10, 8261ss, Barnman1, Bearcat55, bfisher82, bob7794, buzzmonster, campfun, Claude C, CRZ, cstover, dashonthedash, DDC, ddemme, DonG, Emptypockets, Falcon35, fonzie, Freds342, gerrym51, GlacierGus, Greene, ilovecamping, jjacon, kenandterry, Kentdb1, kgmat, lindy, Linnemj, Mad4sax, mamentt, Marc73, Mike G, mike1329, NeilM108, nightcrawler, NO3putt, patov6, Phil57, Poppy Bill, prof_fate, punkaccountant, RattVader, RichN, RickV, rkswyo, Roamin Ovum, Rsgtivr6, Rugged Brown, Rustymax, ryoucrazey, seatosea, ses, shiggs, Smithee, SnowBird9, Sparkbark, SpringerPop, Stank Bait, Stedman1, steeleshark2, Stevea1956, terrystevens, tfennell81, tgarner2000, tking1866, torben, transamz9, vp22er, Walke, Whiteknight
Most users ever online was 1,025, Today at 01:04 PM.
Close [X]
