Old 04-23-2012, 05:45 PM   #1
what will I gain?
Something similar has probibly been asked before. I searched but didn't find what I was looking for.
My year old tt came with an interstate srm-24 battery. I Was offered two new Optima yellow top D34/78 batteries for dirt cheap from an equipment maintainer friend. Battery specs give me a headache and I am looking for an example of how much better, if any, these will do when off the grid (compared to the interstate battery). I haven't boondocked but would like to sometime soon.
An example would be,so I am told, that my current battery would need recharging after a night using the furnace.... could I go longer before needing to recharge? I have already switched to led lights and led TV.
Homey55 is offline   Reply With Quote
Old 04-23-2012, 06:17 PM   #2
I can't speak for the Optimas but with one SRM24 you would be hard pressed to make it through the night. Not sure what you are paying for the Optimas but you may consider adding an additional SRM24. Do you plan to charge batteries with a genny during the day? If so the 2 SRM24s would get you by. Not optimum, but it would work.
2012 Grey Wolf 19RR
2008 Dodge 2500 CTD
Nights camped 2012 - 35
Nights camped 2013 - 46
rkswyo is offline   Reply With Quote
Old 04-23-2012, 07:31 PM   #3
Herk7769's Avatar
Optima D34/78 Yellow Top Battery - 750 CCA: BatteryMart.com
There is also a 25 dollar mail in rebate.
NOTE: These are DUAL purpose batteries which means they are poor performers at both starting engines AND house batteries.
At 55 Ah / 750CCA they pretty much suck for what you want to do. The series 24 battery you currently have in the camper is a 70AH battery.
With two of those you would have 140 AH; with two yellow tops you would have 110 AH.
You can buy a second SRM-24 for 90 bucks.
Interstate SRM-24 Deep Cycle Marine & RV Battery 550 CCA
Your call.
HAM CALLSIGN - KC3FFW
Old 04-23-2012, 07:35 PM   #4
TURBS's Avatar
whats the specs for a group 27 lou ?
so as he might compare some more apples .
Old 04-23-2012, 07:45 PM   #5
Thanks for the replies. Exactly what I was looking for. A second srm24 would be a better choice. Some reason I thought the optima would have been better. I stand corrected.
Old 04-23-2012, 07:46 PM   #6
Herk7769's Avatar
Well the group just describes the physical size of the battery; not its capacity. That is why battery banks have to be made up of identical batteries. My Deka DC-24 is a 75 AH battery (I have a pair of them).
For comparison the SRM-27 is a 78 AH battery and the Deka DC-27 is an 86 AH battery.
Old 04-23-2012, 07:53 PM   #7
TURBS's Avatar
so what would be the point of having a group 27 ? its bigger and heavier so why the slight change in ah ?
Old 04-23-2012, 08:01 PM   #8
Herk7769's Avatar
Percentage wise it is a pretty big increase. Remember you are talking about a lot of amps being released for a long time to generate an amp hour.
House Battery - Amp Hours or Reserve Minutes
The bigger and thicker the plates; the LONGER the amps are available.
Starting Battery - Cold Cranking Amps
The thinner and lighter the plates; the FASTER the amps can be released.
Dual purpose Batteries - Both RC and CCA on the spec sheet.
Middle of the road plate size and thickness.
Name:	Battery Internals.jpg
Old 04-23-2012, 08:02 PM   #9
TURBS's Avatar
gotcha !
