Old 06-04-2011, 03:19 PM   #1
larry69fatboy's Avatar
Wheel Chock & E-Track question
I just purchased a 06' Work and Play 18LT. I want to add 2 removeable wheel chocks and 3 E-track rails to haul two Harleys. My qestion is do you need to back plate under the trailer and bolt them through? Thanks
larry69fatboy is offline   Reply With Quote
Old 06-04-2011, 03:48 PM   #2
The floor in your trailer is 3/4 plywood, covered by a spray in bed liner, or at least that is what is in my 2008 18LT. Removable chocks, I didn't worry about it, just got some on sale at Tractor Supply, and used the hardware provided. I don't put much pressure in the chocks, just mainly use to guide me in. I installed 6 "D" rings, and made sure they went through a cross member or a frame rail, or at least a couple of bolts per ring did. I didn't want to be walking on a track system, or trying to clean under it. Whether you need to put something under your floor is up to you. We haul a Honda 750 Nighthawk, and Yamaha 650 V Star, a little over 500 pound each. I use 4 tie- downs per bike. So far, so good. Hope this helps some.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
