Old 07-04-2015, 07:14 PM   #21
Hi,
My problem is that the stock tires on my Silverback are too close for any of the commercial gizmos to work for me. They simply won't fit in the space between the tires.
Still looking for either a factory option, or a way to do it myself. This has some potential merit.
FWIW.
Rich Phillips
richp is online now   Reply With Quote
Old 07-04-2015, 07:15 PM   #22
Crockett's Avatar
Originally Posted by n-e-d View Post
So what are the odds the OP will post a mod again?
I hope he does...I did...got thicker skin and a bigger pair to boot!!
Crockett is offline   Reply With Quote
Old 07-04-2015, 07:33 PM   #23
Crockett's Avatar
1. swingset gets recycled.
2. swingset gets to travel and see kids he loves play instead of dying
3. 3 times surface area on contact patch means greater load distribution and less
potential tire damage
4. fewer moving parts, composite composition means no splinters, less chance of
splitting.
5. wont burn you if left in sunlight and handled.
6. earth tones more at harmony with camping....possibly better feng shui
7. less cost
8. less affinity...probably wont walk off
9. the "yes I did it myself" factor...
um...thats just the short list!!
Old 07-04-2015, 07:47 PM   #24
Hicks43's Avatar
I made the same things for mine. Not to keep it from rolling away. The chocks do that. But more for movement. In the camper they seam to work well. Cost was nothing stuff I had laying around.
Sent from my iPhone using Forest River Forums 2015 21ss havein fun
Hicks43 is offline   Reply With Quote
Old 07-04-2015, 08:15 PM   #25
Islander's Avatar
"richp"....
My wheels are much closer as well.
I made up these to fit the profile of the tire.
They work very well however, you must always remember to slack them off "before" making any height adjustments.
So they are last to set when level and parked and first to unset before lowering or raising the rig.
The graduating chocks are for the preliminary set up, then I place the tire chocks when everything is level and happy.
They really take the jiggle out of the tire roll.
I am adding a pair of Bal stabilizers at the rear scissor jacks to stop the tail wag.
hope this helps
Islander
Name:	Wheel Chocks 1.JPG
ID:	82070   Click image for larger version
Name:	Wheel Chocks 3.JPG
ID:	82071   Click image for larger version
Name:	Wheel Chocks 4.JPG
'07 WildCat 30 RLBS ~ West Coast Edition ~
Trail Air - Tri Glide Pin Box
2000 F350 Lariat DRW 4x4 7.3 Diesel 89k miles
Edge programmer, 4" SS exhaust turbo/back,
Tru-Cool Max Trans Cooler, Bilstein Shocks
Vancouver Island, B.C., Canada
Islander is offline   Reply With Quote
Old 07-04-2015, 08:18 PM   #26
Hi Islander,
That's a nice piece of work!!!
I was wondering if Anderson levelers accomplish pretty much the same thing as chocks. Any opinions???
Rich Phillips
Old 07-04-2015, 08:19 PM   #27
jmcrae3891's Avatar
This is some engineered wood. It does not split, rot, or warp. It gets wet, it dries, it can be drilled, and its extremely hard to cut.
2003 Dodge Ram QC 2500 4x4
2005 Nissan Altima
2011 Forest River Lacrosse 301RLS
jmcrae3891 is offline   Reply With Quote
Old 07-04-2015, 09:55 PM   #28
Crockett's Avatar
Islander...you've elevated chocks to an art form...
Old 07-05-2015, 09:22 AM   #29
Islander's Avatar
"richp"...
I can't see how the Anderson levelers would act as a good 'locking' wheel chock.
They are more for leveling from side to side.
If you are trying to eliminate movement or jiggling in the rig when people walk around 'locking chocks' between the wheels will help. Along with J T Strong Arm stabilizers or BAL stabilizers ( I a use pair on the rear scissor jacks). I still use a king pin tri-pod stabilizer that works fine for me.
Islander
Old 07-05-2015, 09:32 AM   #30
The Anderson does chock that side well. Won't stop the shakes,but I can feel the difference when we have them in use. Not this weekend because the site is level side to side. Just have the chocks in front and back both sides. DW is complaining about my moving around before she gets up.
DaveandSue is offline   Reply With Quote
chocks, wheel
