Old 11-13-2010, 05:25 PM   #1
wheel chocks details
Can someone please point me to the link that shows how to make the wooden wheel chocks??
All the links I have found lead to nowhere.
TT-2014 Coachmen 320bhds Freedom Express-50 Yr Anniversary edition
TV-2016 Dodge Ram 2500 Cummins Diesel 4x4
2010 Road Glide Harley Davidson FLTRX
boudie is offline   Reply With Quote
Old 11-13-2010, 05:54 PM   #2
If you get the Bal brand X chocks, they fit in between the two tires at their closest point on each side, then ratchet it apart thereby locking the wheels in place, and also stabilizing the camper's movement, as well. About 35.00, money very well spent. Good quality metal construction, too. One for each side works the best, but not necessary. Randy
Old 11-13-2010, 06:35 PM   #3
frankm's Avatar
Very easy to make, here is the link to the thread:
Home made wheel chocks
Here is the finished product:
Name:	wheel chucks.jpg
frankm is offline   Reply With Quote
Old 11-13-2010, 07:42 PM   #4
Thanks Frank BUT when I click on your link it doesnt work> is there any way u can fix it?
Old 11-13-2010, 08:25 PM   #5
frankm's Avatar
That's weird, it works for me w/o problems. Just do a search for "Home made wheel chocks" it should be the first hit. If not just copy this URL and paste on the address bar:
www.forestriverforums.com/forums/f68/home-made-wheel-chocks-8318.html
Old 11-13-2010, 09:38 PM   #6
It still doesnt for me.
the thread shows up but not the details of the mod.
Thas ok. what are the top and bottom measurements of the blocks?
and length of the threaded rod.
Old 11-13-2010, 09:43 PM   #7
bikendan's Avatar
boudie, the measurements are different for different trailers.
not all trailers have the same distance between the axles as yours does.
my Roo 23SS's axles are closer together than other trailers.
there's no standard measurements for these. also, the wood wedges have different angles, based on the distance between the tires.
you have to measure yourself, unless you can find someone with a Roo or Shamrock 19 that has made some themselves.
Old 11-13-2010, 10:43 PM   #8
frankm's Avatar
boudie I can't find the plans I used (they have been removed from the original website) This is the best I could find. All of the following dimensions will depend on the space between your tires (mine are about 3" apart)
The rod is 18"
Top of chock block is 7.5" in length
Bottom of chock block is 4.25" in length
For the top nut I used a wing nut
Hope this helps.
Old 11-14-2010, 07:26 PM   #9
great white's Avatar
Originally Posted by 08flagvlite View Post
If you get the Bal brand X chocks,...
Just googled 'em.
Like 'em a lot!
I especially like that they are "lockable".
I'll be hunted down a set locally me thinks!
great white is offline   Reply With Quote
