08-09-2016, 09:58 PM
When not in use
For those who use their tt 1 time a month or less, when not in use do you drain the water, keep slides in or out or run your a/c ?
I'm not talking about winterizing.
08-09-2016, 10:04 PM
When not in use
I button it up, with slide in and the tanks drained. I don't have electric at my storage location, so no A/C. I wouldn't use it even if I did.
2015 Coachmen Apex 288BHS
2014 Toyota Tundra CrewMax 5.7L
08-10-2016, 12:58 AM
Always keep slides in.
08-10-2016, 01:32 AM
No reason in that short of time to drain the fresh water imho
TH : 2016 Stealth WA2916
TV : 2012 Ford F-250 PSD
08-10-2016, 02:35 AM
Crookedread
Not good advice on the water. Water has a shelf life to it. In one month some pretty nasty things can grow that will make you very sick!! Drain and replace!!
Crookedread
2016 Duramax
2011 Stealth 2312
08-10-2016, 04:09 AM
Regarding the water, my tank is always about 1/3 full (10 - 12 gals) at least from May thru Sept. (my camping season). I use the motorhome about once / month. I put in a little "maintenance chlorine", a tablespoon once / month. Note - I never drink from tank. I've been doing this for about 15 years with no problems or issues.
former 2017 Forest River Sunseeker 2250SLE owner - replaced by a Pleasure-Way Tofino and then an Ontour 2.0
08-10-2016, 04:47 AM
World Wide Wanderer
I have a motor home rather than a TT...
However it is stored right beside my house. Typically slides in, water in the tank. We plug it up 2-3 days before we are getting ready to go on a trip, so the fridge and the A/C can do their thing.
I don't like leaving it plugged up 24/7 due to the possibility of lightning strikes from the summer thunderstorms. We live in a relatively high risk strike area. I have had to replace several things at home in the past due to lightning strikes, don't want to risk having to replace my RV.
Aaron
Aaron & Rhonda
wahoonc & Airangel60
2016 Coachmen Concord 300DS
2015 Fusion Hybrid following along
08-10-2016, 06:05 AM
Canadian Member
I store mine with the slide in, no shore power connected and battery disconnected via shut off switch. I drain my WH, empty the water filter housing and drain from the low point drains if I won't be using it for more than 2 weeks. Takes less than 5 minutes to drain everything.
08-10-2016, 06:24 AM
Slides in, tanks drained, lines drained, WH drained, power disconnected, battery off , roof vents opened, shades down. Doesn't take but 5minutes to do it or reverse process
2016 Flagstaff 27VRL Emerald
14K Equalizer
2020 Silverado 2500HD CC 4X4 6.6L gas 3.73
08-10-2016, 06:33 AM
I keep about 5 gallons of water in each tank with some bleach. I keep it open actually, slides out, and a window or 2 for some fresh air in there. The wife puts fabric sheets in there as well. I keep it plugged in as well, due to sometimes the kids "camp out" in it.
2013 Prime Time Tracer 3200BHT
2016 Chevy 3500 CC, DRW (aka: bigbootyjudy)
Ribs in the smoker and Whiskey in hand
08-10-2016, 08:06 AM
If you fill your fresh water tank from a public water utility, and you don't use a chlorine removal filter, you don't have to worry about the fresh water getting bad in a month.
I only drain and sanitize ours once a year. It gets added to and used from enough to keep a chlorine residual in it.
And I know some of you will faint, but we even drink from it. I personally wouldn't put water in the fresh water tank that isn't fit to drink. If it isn't fit to drink, it isn't going in our FW tank. And yes, I've been in places where the water isn't fit to drink.
Gotta go campin!
08-10-2016, 01:01 PM
We park along side our house. Unit leveled all tanks empty, slides in, battery disconnected, shades pulled, tires covered. Only takes minutes to get everything ready to go. While DW is organizing the inside I get everything ready outside, plug in power to pre cool refrigerator.
2016 Open Range Light 297RLS Fifth Wheel
2015 GMC 2500HD 6.6L Duramax
Days Camped. 2015: 17
Days Camped 2016: 58
08-10-2016, 01:36 PM
x2 on what keeprr replied. Hubby makes sure he drains the hot water heater and inspects the rod (?) also. In fact hubby washes the tt and the same time inspects everything (cover lenses might came off etc). I clean it out good like it is the end of the season. Plus make the bed again after the sheets are washed so I don't have to do it later (I hate making the bed!).
08-10-2016, 03:08 PM
We keep our motorhome here at the house plugged in with fridge, freezer and pantry stocked with the basics. Slides in and tanks drained, tires covered no air on but roof vents open under maxair covers. We clean it and restock it after every trip and I remake the bed and put clean laundry away. When we decide to go somewhere we just need to move perishables from the house fridge to the mojo, uncover the tires, roll up the electrical cord, grab the dog and hit the road. Our current record from idea to departure is 32 minutes.
Phil, Heather & Olaf the Boxer
Ontario Canada
Lexington 283GTS
08-10-2016, 03:58 PM
Slide is in, unless doing cleaning or chores inside. Plugged into power, only 20A though, so no AC. Make sure battery is topped off with a charge and then switched off. Typically after laundry is done, make up the bed for the next trip.
As for tanks, grey is empty. Occasionally, I'll throw some water softener and/or dish detergent in the black tank and nearly fill it with water. There always seems to be an errant piece of tissue or dried waste that never makes it out during dumping/flushing. On the next trip out, I pass right by a truck stop with a dump station, where if I fill the TV, the dumping is at no charge.
As for water tank, I try to keep 5-6 gallons onboard simply because I'll use that toilet while traveling rather than a restroom. We don't use onboard water, any CG we go to has water hookup and we generally always drink bottled water and the same for making ice.
2015 Freedom Express 246 RKS (Sold 2021)
2021 Grand Design Reflection 150 295RL
2016 Chevrolet Silverado 2500HD Z71 LTZ
Days camping previous years: Not Enough
Days camping in 2021: Still Not Enough
08-10-2016, 05:21 PM
ARLO
I store mine with the slide out, plugged in and cable tv hooked up. It is useful as a refuge from my "better" half. I only used my fresh water on any trailer since 1999. That was camping one night in a Walmart parking in Nova Scotia.
08-10-2016, 05:34 PM
We're on well water and so are a number of the campgrounds we stay at. Due to this I always drain the fresh water tank and WH. If we aren't going out again for a few weeks or longer I will re-sanitize the tank and system before we use it again. It might be overkill but it doesn't take very long to do it so I figure why not. We don't drink or cook with our onboard water as I don't like vinyl taste from the hoses that make up part of our plumbing. We do use it for brushing teeth and washing dishes so still need a sanitary system.
08-10-2016, 08:48 PM
Thanks for everyone's input, suggestions are noted.
08-10-2016, 09:58 PM
X2 to Phils input, keep refrig/freeze pluged in. Had more than one occasion to drop everything and meet the Grands in a cg a few miles from home. Mon and Dad are tent campers, grands like the outdoors, eating out by campfire, but at night love the ac, satellite tv and sleeping in with the rescue puppy Pepper. Have not had the luck of refrig being up to full cooling without running it for a least two days, Been true for previous tt, and the new Flagstaff seems to follow the pattern.
2020 Georgetown 31L, Safe T steering, Sumo springs, Onan Geny
2015 GMC Canyon 4X4 TOAD w/Blue Ox tow plates, InvisiBrake
Pepper 🌶 PomChi rescue 545 nights as our camping buddy
Days camped in FR 2011-12 = 77, 13-14 = 98, 15-16 = 129
17 = 81, 18 = 44, 19 = 83, 20= 45, 21 = 76, 22 = 57, 23 = 42
Retired :
08-11-2016, 12:12 AM
I do the same as jeff64 with one exception. I live in the desert so I place a 3 gallon bucket of water in the middle of the trailer. I've found this goes a long way toward saving the wood and upholstery in my unit.
