Old 07-26-2010, 09:21 PM   #11
We waited and looked around something to come up on sale. We ended buying a 22" Element LED (5lbs) for under $200 at Target.
we want to get the 26 LED also when it goes on sale. These TV's are very light and good picture too.
2011 Wildwood 27BHSS
2007 Sub 5.3L 3:73
Hot DW
1 Princess & 2 Busy Boys
Ventura County, CA
Willie is offline   Reply With Quote
Old 07-27-2010, 12:20 PM   #12
Great Info... We take delivery tomorrow, and I don't recall seeing a good place for a DVD player, and I believe the space is recessed, so I am thinking that the ones with the built-in DVD will not work... Will know tomorrow.
Lou_Becky is offline   Reply With Quote
Old 07-27-2010, 03:44 PM   #13
camping
tentcamper1's Avatar
we have the 32" Toshiba LCD,
2007 Chevy 2500HD CC
2010 V-Lite 30WRLTS
Nights Camped 2011 -64
Nights Camped 2012 -50
"I Live in My Own World, But It's OK. They Know Me"
tentcamper1 is offline   Reply With Quote
Old 07-29-2010, 10:04 AM   #14
Turns out it came with a tv.... granted it is a bit small, but it will work for now. I have my eye on a 22' LED TV that will work off of 12V from Walmart...
Old 07-31-2010, 01:03 PM   #15
Mr. Black's Avatar
Went with a 32" LCD. It's a Best Buy house brand. It has been flawless so far. Hardest part was mounting it inside the cabinet to clear the slide. I would like to have fit a 42 but there just is no room.
Next I will likely mount another of the same in the bedroom.
Believe it or not it is wired up through the stock crapcertone which works great.
Steve
1999 Ford Superduty F250 PSD CC SB 6spd 4x4.
B&W goosneck/companion hitch, Airlift 5000 airbags.
2006 Sierra F28 Rear Kitchen 5th Wheel, 31' = 10k pounds.
Nights camped in 09-14, 2010-23
Mr. Black is offline   Reply With Quote
Old 08-02-2010, 12:41 PM   #16
Owner - RVtronics
Bob Fields's Avatar
Send a message via AIM to Bob Fields Send a message via Skype™ to Bob Fields
Looks great!
Bob Fields
bob@rvtronics.com
www.rvtronics.com
(781) 281-9440
Bob Fields is offline   Reply With Quote
Old 08-02-2010, 05:51 PM   #17
MrT
MrT's Avatar
Ditto on the 32" Toshiba 32AV502RZ. I didn't get a bedroom TV, but will likely add one by removing the TV shelf that I keep banging my head on, and subbing a LCD mount.
Anyone have thoughts or pictures on which/whose mount to use?
2017 Cedar Creek 38CK Hathaway Edition
2015 Ford F-350 6.7 CC 4x4
B&W RVK3300
Full-timing since 5/2/2016. Roam Sweet Home.
FROG Int'l Rallies: 2012-2017
MrT is offline   Reply With Quote
Old 09-15-2010, 11:46 AM   #18
locknload's Avatar
Ours came with Toshiba and Konka. I'd like to add a third to the bunk house. Do they have to be 12V or will newer trailers convert a standard TV?
2010 Flagstaff 831RKSS.
2000 Excursion Limited PowerStroke Diesel- ATS ported housing, Riffraff's FRx, HPx & I/C boot kit, DiPricol Optix- Pyro/Boost/Trans, DP Tuner-80t, Drive-Thru, 80e, 120race, K&N intake tube w/6637, Exhaust, AIH delete, Foil delete, 4" lift, Airbags, Dunlop Rover M/TMaxx 315/75/16's, '04 headlights.
locknload is offline   Reply With Quote
Old 09-15-2010, 12:25 PM   #19
Originally Posted by Iggy View Post
Mine came with a 32" Toshiba LCD
Ours came with same one. altho when did the walk through we had to order a new one as it look like they drug it accross the shop floor. we did get a better one when they ordered it. woo hoo!!
trailraider is offline   Reply With Quote
Old 09-30-2010, 07:41 AM   #20
jimh's Avatar
i installed a 22" sharp w/dvd in the bedroom. took the doors off of the fdw cabinet and built a sloaped stand so that the tv would face the head of the bed (both vertical and horizontal). there is a reason they put the tv's at eye level in the store. whatever u buy, check it from the angle ur going to watch it. the plasma's didn't have that problem but they run hot and pricey.
if i ever sell the trailer, i can always reinstall the doors and put a 13" in the orgional slot.
jimh is offline   Reply With Quote
