Old 10-24-2015, 04:41 PM   #11
With my previous 5th wheel- a 2008 28' Rockwood Signature Ultralight with double slide- I triple towed in Minnesota for several years. I replaced the 4" bumper(super thin steel) with a heavier duty 4" bumper that I bolted and welded on to the frame. Never had any issues.
SSmbs is offline   Reply With Quote
Old 10-24-2015, 04:44 PM   #12
Grab some steel and weld up a hitch and Try it . If my state and the neighboring states allowed doubles I would have a hitch welded up in a heartbeat .
Big Red and 30WR is offline   Reply With Quote
Old 10-24-2015, 04:57 PM   #13
That Ranger is a pretty heavy boat/trailer combo. You didn't say what your tow vehicle was. I had a duramax diesel. The heaviest I towed behind 5th was an 18' fiberglass but I don't think it weighed 3400#.
Old 10-25-2015, 05:03 AM   #14
Talk with a custom trailer (RV) manufacturer such as
2013 Flagstaff 8528IKWS, 2006 F-350 6.0L
DickiedooFlagman is offline   Reply With Quote
Old 10-25-2015, 05:38 PM   #15
Thanks All. Really appreciate your thoughts.
With a GM published tow capacity of 20,000 lbs, granted it's a lot of weight but GM would not publish that if the truck wasn't capable. I won't be close to pushing that. Also based on the trailers having good breaks. I understand from the Chevy dealer that the only difference between the 2500 & 3500 was an extra leaf spring. Same brakes and transmission. Since I knew that we'd be limited to <30' 5r there was no benefit to get the 1 ton.
I will be pushing 70' so I will be going to a large empty parking lot the first time out with both trailers to get the feel of it and the required spacing for 90 deg turns.
Looking forward to taking both to SD for fall walleyes in Lake Oahe in the AM and pheasants in the afternoon!
CashRanger is offline   Reply With Quote
5th wheel, wheel, boat
