Originally Posted by The_Rhino
Does anyone have an idea for a door lock for this fridge?
By door lock, I suppose you mean to lock while traveling. I made a small gizmo that works well for us. I removed the cap between freezer and refrigerator door where the hinges are made to go on either side which exposes a screw hole that is sized as M6-1 (metric sized). I ordered from amazon the following to make.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
I cut out a small thin piece of wood also and used some nuts to hold together to result in the following photo of how it works. Sorry, my trailer is in the shop right now for some warranty work, so this is all the photos I have. My wife wrapped the wood with some rubber type material to soften up enough to keep from scratching the doors. This design works great and the door is very secure and we simply unscrew when no longer needed and store in a drawer until needed next time. I put a nut on both sides of the wood a little loose to allow the wood to turn somewhat while you screw in the knob until secure. I added locktite to the knob to insure it does not unscrew from the all thread needed and cut off excess of the all thread that was ordered.
