Old 04-01-2016, 11:51 AM   #1
B D HOWie's Avatar
Wi-Fi repeater install
I finally got around to a permanent installation of my Jefa Tech repeater and 8.5db antenna.
Fabricated a mount (1.5" x 1/8" x 24" aluminum stock) that is secured to the TV crank up antenna with #8 32 x 1/2" x 3 screws.
Name:   ImageUploadedByForest River Forums1459528809.791477.jpg
Name:   ImageUploadedByForest River Forums1459528828.490981.jpg
Name:   ImageUploadedByForest River Forums1459528850.513573.jpg
Name:   ImageUploadedByForest River Forums1459528869.937319.jpg
Ran the cable to the side of the refrigerator vent (white dot in the shadow right of the small mound of goop).
Name:   ImageUploadedByForest River Forums1459528964.189253.jpg
Cautiously drilled a hole from the book rack to the refrigerator vent cavity (yea no wiring).
Name:   ImageUploadedByForest River Forums1459529127.316927.jpg
Name:   ImageUploadedByForest River Forums1459529157.298778.jpg
Velcro'd repeater to cabinet end.
Name:   ImageUploadedByForest River Forums1459529189.462602.jpg
Ran hard wire Ethernet to Blu-Ray DVD player.
Name:   ImageUploadedByForest River Forums1459529349.779115.jpg
Paul
Big Dog House On Wheels
2013 Coachmen Freelander 28QB
on 2012 4500 Chevrolet Chassis
Paul
B D HOWie is offline   Reply With Quote
Old 04-01-2016, 06:45 PM   #2
Ddubya's Avatar
Nice install. Look forward to hearing how it works.
Ddubya is online now   Reply With Quote
Old 04-01-2016, 07:00 PM   #3
Blackhat6mike's Avatar
My experience as a ham radio operator for many years is antennas mounted too close to each other generally interfere with one another if not totally take out each other. My guess is you will seriously diminish one or both signals but for sure the television ant. IMHO I hope I'm wrong, but such have been my experience in the past.
Aviator Wright Flyer #1919
Army Pathfinder Vietnam, 3 tours
DAV, MOPH, VFW, NRA, 1stCav. ABN
Blackhat6mike is offline   Reply With Quote
Old 04-01-2016, 07:11 PM   #4
B and B's Avatar
The wifi will overload OTA Digital signals by increasing the noise floor in the little preamp inside the antenna if not overload it. In layman terms not a good idea.
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 04-01-2016, 07:16 PM   #5
I would relocate the WiFi ant as far away from the TV ant as I could get it. Even then, you may be in for some signal distortion. JMHO
Old 04-02-2016, 06:51 AM   #6
Canadian Member
itat's Avatar
Wifi Ranger products are regularly mounted on the TV antenna. If you guys think B_D_HOWie's setup won't work, what's the difference between his setup and the Wifi Ranger that works fine?
itat is online now   Reply With Quote
Old 04-08-2016, 05:37 PM   #7
B D HOWie's Avatar
Lake Manatee State Park - Florida
No wifi in range. Host says closest is McD's west of here. Not sure how far.
Will advise next trip.
Paul
Paul
Old 04-08-2016, 06:03 PM   #8
It may indeed "work", but how well relative mounting them apart? Unless you have something to compare the two [experience], you will never know.
Many "stacked" ham radio antennas work well if they don't resonate with each other. They will almost always work better on separate mast, but most hams don't either have the room or want to spend the money for numerous towers or mounts. It can get very expensive!
Old 04-08-2016, 06:47 PM   #9
rsdata's Avatar
I am not an antenna expert but a TV antenna only receives and does not transmit... the TV antenna might get some interference introduced into the TV signal but not the other way around... AND it might even work as a ground plane giving the upright antenna some boost...
the antennas that might interfere with each other are the external and internal WiFi antennas if they are too close...
2014 Shamrock 183
2014 RAM 1500 Bighorn Crew Cab, HEMI, 3.21 gears, 8 Spd, 4X4
Old 04-08-2016, 06:59 PM   #10
First of all, this antenna is not 8db, you will never gain 8db out of a vertical. As for the "plane" they would have to be bonded, right there, not going through the whole trailer.
If you want some advice, ditch that antenna, keep the router. And get youself a directional antenna made by Alfa networks, take advantage if a rotating "support". Cant remember what model number is now, but they are small, black, and are about 25-30$ on ebay. If interested in something better, look into alfa's R36 combos. If not misteaken they are 2000mw.
Doubt that old linksys will support all bands as well, abgn.
You will see NIGHT AND DAY difference with either a panel antenna or that small black one from alfa guaranteed.
When i used the omni first i saw maybe 5 networks around my site, once i plugged my dir one, there was about 40 of them around depending where the antenna was pointed.
Nice job on wiring.
Kuba is offline   Reply With Quote
