07-25-2011, 11:48 AM
Wifi question: want to receive park wifi signal into my wireless router
I've searched on Google, although maybe I'm not using the appropriate terminology or keywords to get the right answer, because I haven't really found any answers that I can understand. So here's the task:
I want to use a cantenna or some other directional type wifi antenna to receive the park-provided wifi signal as my ISP. BUT I want to use my own private, secure wifi network that I've already got configured. My wifi router has a USB port that I've got a backup drive plugged into. I don't want to connect my computer/ipad directly to the park wifi, I want to use my own secure network. What the heck sort of device do I need to accomplish this? It needs to be able to receive a wifi signal via. coaxial connector (hooked to the external antenna), and output this signal via. ethernet so I can plug it into my wifi router. OR, replace my wifi router with a single device that could accomplish this.
07-25-2011, 12:49 PM
The term you are looking for is "repeater" or "repeater Bridge" depending on your router you have a couple or choices, if your current router supports repeater bridging you can just configure it, if not you need to get a second router that does and then put a physical cable between to two, if you want an external antenna then you have to go to option two and also make sure you get a router that supports an external antenna. The links below are a start to help you.
Linking Routers - DD-WRT Wiki
Wlan Repeater - DD-WRT Wiki
2011 GMC 3500HD 4x4 Crew DRW Duramax
Pullrite 20.5K
2012 Sierra 365SAQ
2006 Police Roadking FLHPi
07-25-2011, 02:14 PM
Originally Posted by HomeGrown
I just bought something a few weeks back that may fill your needs that they were talking about on another trailer forum. It is a repeater/router with a omni directional antenna. You can configure your own local area network (LAN) that you can secure. I got it on sale cheaper than what is currently advertised, so you might can get it at a lower cost.
JEFA Tech: Long Range WiFi Repeater Kit for RVs
http://support.jefatech.com/index.ph...d=17&nav=0,4,5
If you are cross-eyed and have dyslexia, can you read all right?
07-25-2011, 02:42 PM
Thanks for the info and links guys, looks like I should be able to find what I need.
I was aware that I probably needed something like a repeater, but didn't know if it would suit my needs.
Thanks again!!
| Thread Tools |
| Display Modes |
» Recent Threads |
» Online Users: 513 |
| 78 members and 435 guests |
| 02 rockwood, 2007Rockwood2601, 4bnabird, 4Jeeperz, 64c10, Barnman1, Bearcat55, bfisher82, bob7794, Bruck, buzzmonster, campfun, Claude C, CRZ, cstover, dashonthedash, daveinpickerington, DDC, ddemme, DonG, Elidh, Falcon35, Freds342, gerrym51, Greene, ilovecamping, jharvey, jjacon, jojo bamboo, Kentdb1, kgmat, lindy, Linnemj, Mad4sax, mamentt, Marc73, Mike G, mike1329, mtusrsmith, NeilM108, nightcrawler, NO3putt, patov6, Phil57, prof_fate, punkaccountant, RattVader, RichN, RickV, rkswyo, Roamin Ovum, Rsgtivr6, Rugged Brown, Rustymax, ryoucrazey, seatosea, ses, shiggs, Smithee, SnowBird9, southernsky, Sparkbark, SpringerPop, Stank Bait, Stedman1, steeleshark2, Stevea1956, terrystevens, tgarner2000, tking1866, torben, transamz9, Trevor43, tshayn, vliterick, vp22er, Walke, Whiteknight |
| Most users ever online was 1,025, Today at 01:04 PM. |
