Old 07-04-2018, 01:38 PM   #1
WiFi Receiver...
I am sure this has been a topic before, but just sharing my version. WiFi Ranger was way overpriced so I created my own solution.
ID:	178281Click image for larger version
ID:	178282Click image for larger version
larryscsi is offline   Reply With Quote
Old 07-05-2018, 11:04 AM   #2
Now tell us what equipment it is, almost looks like the ubiquiti airgateway.
2015 silverback 31IK
2023 f350
kcmusa is offline   Reply With Quote
Old 07-05-2018, 11:27 AM   #3
It is the air gateway LR with the POE injector. Up CAT 6 to the Ubiquiti bullet. The bullet will use a “N” antenna connection. In my case, I used a TP Link antenna. Very simple system.
Old 07-05-2018, 11:31 AM   #4
Can you put it in layman‘s terms for us nontechies thanks
2017 Sanibel 3601
2015 F350 - 6.7 Diesel
Retired SMsgt USAF 21 years
6 years weekend camping Class C
2017 camping 20 days and counting
Brand2328 is offline   Reply With Quote
Old 07-05-2018, 06:59 PM   #5
Ubiquiti Air Gateway = Router inside the trailer for all wireless devices to connect to. It creates a local network based on the amplified WiFi connection received via the antenna (the campground WiFi). The POE Injector = device that takes the 12volt or AC current over the Ethernet cable to the Ubiquiti Bullet. The Bullet is the WiFi access point. The antenna is a TP Link antenna is a 15dbi Omni direction antenna. This means that I don’t have to point the antenna in the direction of the signal. It will pick up any network from 360 degrees. The Ubiquiti software allows sorting of all networks that are found by signal strength, and then you connect it to the one you like.
Old 07-05-2018, 08:57 PM   #6
XenoRev's Avatar
Would you share a part number list or PM me? Very interested in your setup.
2018 Salem 27DBK/2010 Dodge Ram 1500 Laramie
Days past:1996 Coachman Capri-Ruby Ed. 27DS
2004 Ram Quad 1500
1995 GMC Yukon Sport
1986 Jayco1016PUP
Days Camped:'13-10 '14-20 '15-6 '16-9 '17-14 '18-3 '19-12 '20-14 '21-12
XenoRev is offline   Reply With Quote
Old 07-05-2018, 09:06 PM   #7
Who Dares, Wins
doc73's Avatar
He got an internet wireless thingy... Plugged it into an antenna thingy with a phone line... Which makes a wicked signal for the daily fix of FRF!!!!
2015 Chevy HD D-Max
2022 Impression 315MB
doc73 is offline   Reply With Quote
Old 07-05-2018, 09:18 PM   #8
That splains it more better!
Old 07-05-2018, 09:32 PM   #9
Search Amazon or EBay for best prices:
Ubiquiti BM2-TI-US 2.4GHz Bullet M2 Titanium Access Point
Ubiquiti airGateway LR Wireless access point 802.11 b/g/n
Ubiquiti POE 12-24W-G Power OverEthernet Injector
Cable Matters Snagless Cat 6a/Cat6a (SSTP/SFTP) Shielded Ethernet Cable in Black 20 Feet - Available 1FT - 200FT in Length
TP-Link 2.4GHz 15dBi Outdoor Omni-directional Antenna, N Female connector, weather resistant (TL-ANT2415D)
Old 07-06-2018, 05:44 AM   #10
XenoRev's Avatar
Thanks, found all.
2004 Ram Quad 1500
1986 Jayco1016PUP
Old 07-06-2018, 12:26 PM   #11
Canadian Member
Thanks for your post.
Doing a quick search online, for the POE, should the model number be POE 24-12W-G?
https://www.ubnt.com/accessories/poe-adapters/
Old 07-06-2018, 01:12 PM   #12
Probably. I am not the best at typing via thumbs.
The AirGateway LR is works with 15V/0.8A or 24V/0.5A POE Adapters.
The 24-12W-G. Is the one I chose and fits in the mounting bracket that comes with the AirGateway LR.
Old 07-09-2018, 08:21 PM   #13
First camping trip with the set up. I have 6 people connected, and getting great speed for a Campground. 4.06Mbps Down, 1.95Mbps Up. YouTube and Live TV, email and FRF, no prob!
Old 07-10-2018, 06:32 AM   #14
XenoRev's Avatar
Sounds like it works well!
2004 Ram Quad 1500
1986 Jayco1016PUP
Old 07-10-2018, 11:14 AM   #15
Canadian Member
Pretty good results for a campground. Just make sure you are OK to use a lot of data on their Wifi network. Most don't want you downloading videos or streaming on their Wifi. You don't want to be "That Guy" hogging all their bandwidth!
Old 07-10-2018, 11:30 AM   #16
Just testing. Mostly email, FB, FRF, Messages. But, I have the ability to be “That Guy”!
Old 07-10-2018, 11:40 AM   #17
hammer55's Avatar
what is the black item stuck to the roof, is it waterproof
Attachment 178280
Attachment 178281Attachment 178282Attachment 178283
Mark & Annie
2014 COACHMEN PURSUIT 27 KB
Modesto, Central California
hammer55 is offline   Reply With Quote
Old 07-10-2018, 02:18 PM   #18
XM antenna, I used that access to route the wire. Go figure, about an inch & 1/2 hole for a tiny XM antenna, but it came down in a great location.
