07-04-2018, 01:38 PM
WiFi Receiver...
07-05-2018, 11:04 AM
Now tell us what equipment it is, almost looks like the ubiquiti airgateway.
2015 silverback 31IK
2023 f350
07-05-2018, 11:27 AM
It is the air gateway LR with the POE injector. Up CAT 6 to the Ubiquiti bullet. The bullet will use a “N” antenna connection. In my case, I used a TP Link antenna. Very simple system.
07-05-2018, 11:31 AM
Can you put it in layman‘s terms for us nontechies thanks
2017 Sanibel 3601
2015 F350 - 6.7 Diesel
Retired SMsgt USAF 21 years
6 years weekend camping Class C
2017 camping 20 days and counting
07-05-2018, 06:59 PM
Ubiquiti Air Gateway = Router inside the trailer for all wireless devices to connect to. It creates a local network based on the amplified WiFi connection received via the antenna (the campground WiFi). The POE Injector = device that takes the 12volt or AC current over the Ethernet cable to the Ubiquiti Bullet. The Bullet is the WiFi access point. The antenna is a TP Link antenna is a 15dbi Omni direction antenna. This means that I don’t have to point the antenna in the direction of the signal. It will pick up any network from 360 degrees. The Ubiquiti software allows sorting of all networks that are found by signal strength, and then you connect it to the one you like.
07-05-2018, 08:57 PM
Would you share a part number list or PM me? Very interested in your setup.
2018 Salem 27DBK/2010 Dodge Ram 1500 Laramie
Days past:1996 Coachman Capri-Ruby Ed. 27DS
2004 Ram Quad 1500
1995 GMC Yukon Sport
1986 Jayco1016PUP
Days Camped:'13-10 '14-20 '15-6 '16-9 '17-14 '18-3 '19-12 '20-14 '21-12
07-05-2018, 09:06 PM
Who Dares, Wins
He got an internet wireless thingy... Plugged it into an antenna thingy with a phone line... Which makes a wicked signal for the daily fix of FRF!!!!
2015 Chevy HD D-Max
2022 Impression 315MB
07-05-2018, 09:18 PM
That splains it more better!
07-05-2018, 09:32 PM
Search Amazon or EBay for best prices:
Ubiquiti BM2-TI-US 2.4GHz Bullet M2 Titanium Access Point
Ubiquiti airGateway LR Wireless access point 802.11 b/g/n
Ubiquiti POE 12-24W-G Power OverEthernet Injector
Cable Matters Snagless Cat 6a/Cat6a (SSTP/SFTP) Shielded Ethernet Cable in Black 20 Feet - Available 1FT - 200FT in Length
TP-Link 2.4GHz 15dBi Outdoor Omni-directional Antenna, N Female connector, weather resistant (TL-ANT2415D)
07-06-2018, 05:44 AM
Thanks, found all.
2004 Ram Quad 1500
1986 Jayco1016PUP
07-06-2018, 12:26 PM
Canadian Member
Thanks for your post.
Doing a quick search online, for the POE, should the model number be POE 24-12W-G?
https://www.ubnt.com/accessories/poe-adapters/
07-06-2018, 01:12 PM
Originally Posted by itat
Probably. I am not the best at typing via thumbs.
The AirGateway LR is works with 15V/0.8A or 24V/0.5A POE Adapters.
The 24-12W-G. Is the one I chose and fits in the mounting bracket that comes with the AirGateway LR.
07-09-2018, 08:21 PM
First camping trip with the set up. I have 6 people connected, and getting great speed for a Campground. 4.06Mbps Down, 1.95Mbps Up. YouTube and Live TV, email and FRF, no prob!
07-10-2018, 06:32 AM
Sounds like it works well!
2004 Ram Quad 1500
1986 Jayco1016PUP
07-10-2018, 11:14 AM
Canadian Member
Pretty good results for a campground. Just make sure you are OK to use a lot of data on their Wifi network. Most don't want you downloading videos or streaming on their Wifi. You don't want to be "That Guy" hogging all their bandwidth!
07-10-2018, 11:30 AM
Just testing. Mostly email, FB, FRF, Messages. But, I have the ability to be “That Guy”!
07-10-2018, 11:40 AM
what is the black item stuck to the roof, is it waterproof
Mark & Annie
2014 COACHMEN PURSUIT 27 KB
Modesto, Central California
07-10-2018, 02:18 PM
XM antenna, I used that access to route the wire. Go figure, about an inch & 1/2 hole for a tiny XM antenna, but it came down in a great location.
