05-19-2011, 10:51 PM
#21
Moderator
http://www.campingworld.com/shopping...ewer-kit/44151
Thought I would take another stab at it before I call it a night. Is the white piece on the end of the swivel fitting removable? I found out the end orange cone looking piece that goes into the sewer drain can be remove with a twist. I'm thinking maybe its the white piece that does not fit inside the bumper.
Great choice for "Living within my means" and camping for one... 2011 Salem Cruise Lite 20RBXL & 2011 Toyota Tundra Dbl Cab 16 Trips / 43 Nights / 1204 Miles
05-20-2011, 07:46 AM
#22
Just wanted to let everyone know... black zip ties are UV protected and meant for outdoor use...
2007 Ford F150 Crew Cab 4x4
2011 Windjammer 3006W
05-20-2011, 11:56 PM
#23
Ahh the white piece is a fun one. Just like the other end too. Yes it does come off. The large brown collar below it has the <= loosen / tighten=> arrows. This completely removes the fittings from the hose. I do not do this as the white part is smaller than the 4 large brown tabs on that collar. Those tabs have to be alligned with the corners of my bumper to insert.
Here is how i get it out. I got real thin steel cable 1/32 or 1 /64 and wrapped and secured it behind the collar with those "U" shaped wire clamping bolts. The other end of the wire is poked thru a small hole then looped through the large hole on my bumper end cap. So i just remove the end cap and keep pulling.
I Will see if i can post some pics this weekend
05-21-2011, 12:04 AM
#24
Got the smallest of this and wire to match
http://www.lowes.com/pd_139305-37672...&stop_mobi=yes
05-23-2011, 01:05 AM
#25
PVC Gutter Slide Out
I saw a couple of you guys doing this on the site and loved the idea. My father-in-law is notorious for stopping on the side of the road and grabbing stuff he sees. We try to discourage this behavior but he won't change his ways. In fact, I've even caught myself wanting to stop when I see something particularly appealing.
I don't know when, and it was likely even before I met him, but he picked a PVC gutter 10' piece on the side of the road. Today he cut it in half and kept one for him, and gave me one. I slid it in my bumper tube I built last week and it fit perfect. I did drill two small holes on the sides of each end and ran a zip tie through it so it would "catch" anything trying to slide outside of it. The one on the end nearest me had an unintended but nice effect of making a handle of sorts to grab and pull it with too.
I'm thinking I've spent all the time on sewer at this point than I'd like, but I'm pretty sure that's just wishful thinking.
05-23-2011, 01:06 AM
#26
P.S. I'll be upgrading all my exterior zip ties to UV rated black ones next weekend just to be safe.
05-23-2011, 03:04 PM
#27
Good plan. The white ones become brittle in the sun and could just fall apart.
05-23-2011, 03:29 PM
#28
Lou Amadio
Actually, my hose set stays in the bed of the truck with the generator. I have a large plastic milk crate (actually an Aluminum can recycling bin) that is threaded through the generator hold down strap. The hose airs out and drys out while we travel. The spare length is on a carrier I made from a small diameter PVC tube and two end disks made of nylon cutting board circles. One end is held on with an end cap, the other has a hole through it and a safety pin. That is also stored in the truck bed.
Lou and Laura Amadio and Bella the German Short Hair Pointer
2010 Flagstaff 8526RLWS 5th Wheel Pullrite Hitch
(2009: 28) (2010: 74) (2011: 93) (2012: 7)
05-23-2011, 04:06 PM
#29
Moderator
I store my sewer hoses in a plastic container in the storage bin. I used to keep it in a double plastic bag without any problem but wanted more protection.
My Rhinoflex hose can fit in the bumper if inserted at the right angle but it's a snug fit. I'm not ready to trust the bumper caps yet to stay in place during travel. I like the way many people here have made a carrier out of fence posts. You should take a peek at pictures when you have a moment.
| Thread Tools |
| Display Modes |
» Recent Threads |
» Online Users: 515 |
| 78 members and 437 guests |
| 02 rockwood, 2007Rockwood2601, 4bnabird, 4Jeeperz, 64c10, Barnman1, Bearcat55, bfisher82, bob7794, Bruck, buzzmonster, campfun, Claude C, CRZ, cstover, dashonthedash, daveinpickerington, DDC, ddemme, DonG, Elidh, Falcon35, Freds342, gerrym51, Greene, ilovecamping, jharvey, jjacon, jojo bamboo, Kentdb1, kgmat, lindy, Linnemj, Mad4sax, mamentt, Marc73, Mike G, mike1329, mtusrsmith, NeilM108, nightcrawler, NO3putt, patov6, Phil57, prof_fate, punkaccountant, RattVader, RichN, RickV, rkswyo, Roamin Ovum, Rsgtivr6, Rugged Brown, Rustymax, ryoucrazey, seatosea, ses, shiggs, Smithee, SnowBird9, southernsky, Sparkbark, SpringerPop, Stank Bait, Stedman1, steeleshark2, Stevea1956, terrystevens, tgarner2000, tking1866, torben, transamz9, Trevor43, tshayn, vliterick, vp22er, Walke, Whiteknight |
| Most users ever online was 1,025, Today at 01:04 PM. |
