Forest River Forums
Sunline User Photos
Old 03-15-2011, 10:18 PM   #1
Wildwood 26BH Xlite sewer hose storage
Just got my TT and wondering where and how other 26BH owners store their sewer hoses. It does not have a tube bumper since it is the back pack edition.
Paul
Paul & Karen and the 2 Little ones in tow.
2007 Nissan Armada LE
2012 Wildwood 26BH XLite
20 Nights campled in 2011.
25 Nights Planned for 2012!
pandkm is offline   Reply With Quote
Old 03-15-2011, 11:25 PM   #2
Moderators' Assistant
bikendan's Avatar
if you don't have the typical square bumper, others strap PVC or resin fence posts, with caps, to carry their hose.
you can find pre-made ones at CW but they aren't cheap.
Old 03-16-2011, 06:05 AM   #3
Joe S's Avatar
I installed a 8ft piece of 4 inch ABS pipe with caps using large hose clamps. I did have to cut a notch in the end. I also drilled holes along the bottom for drainage. Looks good and very functional. I store 2 10 ft drain hoses in it. Congrats on the new trailer
Joe S is offline   Reply With Quote
Old 03-16-2011, 12:45 PM   #4
leencharlotte's Avatar
I did this as well. Unfortunately, my Rhinoflex, with the attached end pieces didnt fit. So i ended up using my 4x4 bumper, which fits only at the righ angle...
If your hose has permanent attchments, you may want to consider a fence post or larger PVC. Lowes went from 4"-6" and a huge price difference as well. Fence post should be less expensive
2011 Heritage Glenn 312QBUD
leencharlotte is offline   Reply With Quote
Old 03-16-2011, 03:12 PM   #5
I store mine in a plastic container and keep it in the small storage compartment. Of course I keep it clean to avoid odors.
Tank Wilson is offline   Reply With Quote
Old 05-16-2011, 01:39 PM   #6
I know this post is a few months old but I was trying to find pictures of something like this for my project. I just installed mine Saturday, and I took pics to hopefully help you guys out.
Materials List:
I went to Lowes and bought a 96" 4x3/4" post (5" post) of white PVC for fences.
2 Fence Post Caps for that size (should be right there together)
PVC Cement
U-bolt for handle
2' length of nylon rope
Drill bits
4 1"x3/8" bolts, washers, lock washers, nuts.
Zip Ties
Sand Paper
1. I measured and cut the tube to the length of the bumper, leaving about 1" on each side so the fence posts can protrude without hitting the bumper. Use sandpaper to clean up burs on the cut side.
2. Zip tie the tube to the back of the bumper securely.
3. Drill holes from the bumper toward the tube and (2 on each side, about 12 - 16" apart) to hold the bumper in place. Secure with nut head inside the tube and thread going outward through bumper like this:
Bolt -> Washer -> Tube -> Bumper -> Washer -> Lock Washer -> Nut
4. Now bumper should be pretty sturdy. I chose to keep the zip ties in place so I have 2 means of support.
5. Drill small holes every 12" apart or so on the bottom of the tube for drainage.
6. On the end you choose to seal, cement the cap to the post.
7. On the other end, install the U-Bolt to the post cap by drilling through and installing the bar and nut combo inside the cap, making a nice retractable handle for your fingers.
8. On the removable cap, also drill a hole for the rope, and do so also on the tube near the end as well. This will create a tether in case it falls off during travel.
9. I also applied some friction tape to the edges of the cap so that it will hold securely.
http://www.forestriverforums.com/Pho...&size=big&cat=
http://www.forestriverforums.com/Pho...o=919&size=big
http://www.forestriverforums.com/Pho...=918&nocache=1
By the way, most people will want to install the removable side on the other side, due to where the sewer hookups are. I actually plan on having both sides removable and just decided to complete this side first.
Looking back at the project, I'll probably just swap the two end caps and solve that problem. The only change would be to drill a hole for the rope tether on the other side too.
fajitas21 is offline   Reply With Quote
Old 05-17-2011, 08:15 AM   #7
Lou Amadio
herk7769's Avatar
I love the look, but a warning as well.
Zip Ties degrade in sunlight. They will break while you are traveling and the folks behind you will not be happy. Replace them with screw clamps of the correct size.
Lou and Laura Amadio and Bella the German Short Hair Pointer
2010 Flagstaff 8526RLWS 5th Wheel Pullrite Hitch
(2009: 28) (2010: 74) (2011: 93) (2012: 7)
herk7769 is offline   Reply With Quote
Old 05-17-2011, 08:33 AM   #8
onetonford's Avatar
X2 on replacing the zip ties with hose clamps. I have mine stored in the fence post also I will try to get some pics later.
2001 Ford F-350 DRW 7.3
2011 25 RL Wildcat
former fiver 1976 Fourwinds had for 35 years
onetonford is offline   Reply With Quote
Old 05-17-2011, 09:19 AM   #9
I found a metal clamp at tractor supply that I am trying to figure a clean way to mount. Any pics you can share would be great.
Old 05-17-2011, 12:03 PM   #10
Lou Amadio
herk7769's Avatar
This was the type of clamp I was thinking about. That way you can open it, slip it completely around the white plastic and bumper with the screw drive between the bottom of the metal bumper and the bottom of the white plastic post. The clamp could be bent at 90 degrees angles when tight enough to know where they will fall.
» Online Users: 517
80 members and 437 guests
02 rockwood, 2007Rockwood2601, 4bnabird, 4Jeeperz, 64c10, Barnman1, Bearcat55, bfisher82, bob7794, Bruck, buzzmonster, campfun, Claude C, CRZ, cstover, dashonthedash, daveinpickerington, DDC, ddemme, DonG, Elidh, Falcon35, Freds342, gerrym51, Greene, Iggy, ilovecamping, jharvey, jjacon, jojo bamboo, Kentdb1, kgmat, lindy, Linnemj, Mad4sax, mamentt, Marc73, Mike G, mike1329, mtusrsmith, NeilM108, nightcrawler, NO3putt, patov6, Phil57, prof_fate, punkaccountant, RattVader, realebill, RichN, RickV, rkswyo, Roamin Ovum, Rsgtivr6, Rugged Brown, Rustymax, ryoucrazey, seatosea, ses, shiggs, Smithee, SnowBird9, southernsky, Sparkbark, SpringerPop, Stank Bait, Stedman1, steeleshark2, Stevea1956, terrystevens, tgarner2000, tking1866, torben, transamz9, Trevor43, tshayn, vliterick, vp22er, Walke, Whiteknight
Most users ever online was 1,025, Today at 01:04 PM.
Close [X]
