Old 03-14-2019, 08:10 AM   #11
Originally Posted by wrapperman View Post
If the White House is a PEX house, then yes.
Usually PEX hoses have printing on them, indicating it is a PEX hose.
Wow, I sure do need to reread my post before pressing the "post button".
Hope you solved your problem.
2013 Georgetown XL 378
2008 Honda CR-V
wrapperman is offline   Reply With Quote
Old 03-14-2019, 10:09 AM   #12
Originally Posted by Indy500 View Post
I need to know if a sharkbite will work on the white hose? Bypassing the filter , and on the inlet side I have blue pex on the other side I have a white hose . Will s sharkbite work on the white hose?lAttachment 198707Attachment 198709
If your objective is to bypass the water filter you could use this water heater by-pass kit which would require no additional fittings or modifications:
https://www.amazon.com/Valterra-P235...s%2C157&sr=8-5
Here is a (poor quality) pic of my installation:
Name:	Filter By-pass.jpg
Cathy & Jeff
Midland, Michigan
2013 Sabre 32RCTS / 2012 Ram2500 Hemi
On Order: 2020 Cedar Creek 34IK/2019 Ram3500 CID
SimchaSabre is offline   Reply With Quote
Old 03-14-2019, 10:42 AM   #13
dbledan's Avatar
How did you unscrew the filter connections without cutting a pipe?
dbledan is offline   Reply With Quote
Old 03-14-2019, 11:25 AM   #14
Indy500's Avatar
I wondered the same thing
Indy500 is offline   Reply With Quote
Old 03-14-2019, 01:26 PM   #15
Sorry, I failed to study the pics close enough. My filter was plumbed in using 1/2" male connectors so all I had to do was twist them off. In your case, I'd invest in acquiring PEX capability as others have suggested. You can use PEX clamps and compression tool with the RV white tubing and PEX connectors.
Cathy & Jeff
Midland, Michigan
Old 03-14-2019, 01:33 PM   #16
Indy500's Avatar
Ok thank you
Old 03-14-2019, 02:36 PM   #17
Dahagen
I added Sharkbite on/off valves to my toilet line and water pump line a few years ago without a problem. The water pump one was to keep the city water input from backflowing into the fresh water tank. White PEX lines.
dahagen is offline   Reply With Quote
Old 03-14-2019, 03:58 PM   #18
DaGrinch's Avatar
Pictures?
"Sunny" the 2017 Sunseeker 3010DS
2006 Jeep Liberty Toad
.... and lovin' life........MOST of the time.
DaGrinch is offline   Reply With Quote
Old 03-14-2019, 04:10 PM   #19
Iwannacamp's Avatar
If you can squish it flat between your fingers... it isn't PEX and do not use PEX type Sharkbite type fittings, then I feel the same about "Sharkbite" type fittings as others do about plugging a tire. With these type fittings is just a matter of time before they leak. YMMV
2017 Puma 297RLSS
2005 Ram 2500 4X4 diesel
Old 03-14-2019, 08:05 PM   #20
Dahagen
Originally Posted by DaGrinch View Post
Pictures?
This is it. Both are the same.
