Old 03-13-2019, 08:07 PM   #1
Indy500's Avatar
Will a sharkbite work?
I need to know if a sharkbite will work on the white hose? Bypassing the filter , and on the inlet side I have blue pex on the other side I have a white hose . Will s sharkbite work on the white hose?lClick image for larger version
ID:	198707Click image for larger version
Indy500 is offline   Reply With Quote
Old 03-13-2019, 08:11 PM   #2
If the White House is a PEX house, then yes.
Usually PEX hoses have printing on them, indicating it is a PEX hose.
2013 Georgetown XL 378
2008 Honda CR-V
wrapperman is offline   Reply With Quote
Old 03-13-2019, 08:13 PM   #3
allot of those flex hoses after different outside diameters.
Kimber45 is online now   Reply With Quote
Old 03-13-2019, 08:14 PM   #4
dbledan's Avatar
Originally Posted by Indy500 View Post
I need to know if a sharkbite will work on the white hose? Bypassing the filter , and on the inlet side I have blue pex on the other side I have a white hose . Will s sharkbite work on the white hose?lAttachment 198707Attachment 198709
I had the same setup and was not confident it would work. I cut the right side and unscrewed the left side leaving the threaded connector attached.
I used a sharkbite on the pex side that had a 1/2 screw on connector and a coupler.
Sorry it does not answer your question but does provide a means to an end hopefully.
dbledan is offline   Reply With Quote
Old 03-13-2019, 08:23 PM   #5
You might consider using a water heater by pass kit. It fit perfectly on mine
Cathy & Jeff
Midland, Michigan
2020 Cedar Creek 34IK / 2019 Ram3500 CID
SimchaSabre is offline   Reply With Quote
Old 03-13-2019, 09:13 PM   #6
Canadian Member
You should be able to cut the 1/2” vinyl tubing to allow you to twist off the filter hardware and then use this 1/2” barb splicer and hose clamps to splice the tubing back together.
https://www.homedepot.com/p/Everbilt...0079/300096845
I used a 1/2” PVC union to connect the threaded fittings where the filter hardware was.
Edit: This what it will look like except you have the vinyl tubing on the left (filter outlet line). I had PEX so I used a Sharkbite push-on coupling on the PEX. Sorry the pic turns on its side.
2019 Rockwood Signature 8290BS
Old 03-13-2019, 09:39 PM   #7
WFD
That white hose is not pex, it is simply a white braided hose, much like a garden hose material. It has an inner and outer jacket. Sharkbites dont work on them. You can clamp the white braided hose as is shown in itat's picture. Word of caution though...I did that, and when I checked on it the next day there was a huge blister full of water between the inner and outer jacket, so eventually it would have burst. Somehow the inner jacket must have received a puncture in order to form the blister. I ended up pulling it out and simply replumbing with pex. Pex is cheap and most stores sell it in shorter lengths. I bought a 10 ft length and some shark bites and it has been fine for 2 years plus now.
As my RV mobile tech put it....that white braided hose is junk and should never be used. He pulls it out whenever doing plumbing fixes for people.
2016 Chevy Silverado 2500 Duramax
2016 Rockwood 8289WS, Diamond Pkg.
WFD is offline   Reply With Quote
Old 03-14-2019, 05:29 AM   #8
Indy500's Avatar
Attachment 198714
Thank you very much . That will work .
Old 03-14-2019, 05:33 AM   #9
Indy500's Avatar
If I switch to pex, I will need to purchase a crimping tool . I have no idea what that will cost. But thanks
Old 03-14-2019, 07:56 AM   #10
$25.58
Bob
https://www.amazon.com/Jinwen-120017.../dp/B074K6R4D2
HappyTrav is offline   Reply With Quote
