Old 01-25-2011, 06:53 AM   #11
KyDan's Avatar
Originally Posted by mtnguy View Post
My DD and SIL have something like this with access doors on the top: Propane Tank Covers on Sale
A previous trailer came with this cover. You can't see in
the photo but it has little removable panels over each
tank valve. This allows me to easily access the valves to
open or shut them.
I modified it by using a hole saw to cut an opening in
the front next to the regulator red/green indicator.
I fastened a small piece of Plexiglas over the hole so
now I have a window that lets me see if the regulator has
switched tanks.
NOTE. My cover leaks water thru the top panels so
the tanks get wet when it rains. I paint them periodically
if they start to get too rusty. Since tanks get cold when
you are using them they tend to sweat and get wet
anyway. I don't really think the leaky top access panels
are causing more rust than I'd have without them.
PS when we traded trailers I kept my "accessible" LP
cover and we just swapped them on the lot as I was
trading my previous trailer in.
Peace!
Dan & Rita D
Blue Ox WD hitch
Old 01-25-2011, 05:39 PM   #12
Smile
Originally Posted by grhodes50 View Post
My tt came with a tank cover that has an access door. Here's a couple of pics.
It shouldn't be too hard to make something similar in your tank cover.
The only draw back is you can't read the red/green indicator unless you remove the cover.
My tank cover is identicle and that is why I cut the window in mine. I didn't like removing the cover to see the regulator.
tejano is offline   Reply With Quote
Old 01-25-2011, 05:49 PM   #13
itch'n to road trip
campnqueen's Avatar
Send a message via AIM to campnqueen Send a message via MSN to campnqueen Send a message via Yahoo to campnqueen
Originally Posted by The Danish Guy View Post
Try to move the tanks closer together.The cover might then be easier to remove.
we will try this.
2012 Ford F-250 King Ranch Super Crew Cab 4x4 "Mae West"
2014 Work & Play 25ULA "Ula"
Paula Drake, Ken Cooksey, Sunny Delight & Valor
Jasper Ga.
campnqueen is offline   Reply With Quote
Old 01-25-2011, 05:51 PM   #14
itch'n to road trip
campnqueen's Avatar
Originally Posted by scubieman View Post
I would not let tanks be exposed, the tanks may rust in unwanted areas quickly.
True...but the bottom is open and moisture can get inside anyway. Maybe not as much as when it rains...but this is something to think about.
Jasper Ga.
Old 01-26-2011, 06:50 AM   #15
KyDan's Avatar
Believe me if I could easily and conveniently keep them
dry I would do that.
ANY of my previous LP covers did not really keep water
out of the tray where the tanks sit. The bottom ring on the
tanks and the tray itself seems to be the most prone to
rusting. Every 2 or 3 years I get out the black rustoleum
for the tray and white for the tanks. It's just part
of ownership.
I took a couple feet of 1/4 inch ID rubber hose (industrial
air hose or automotive fuel line will work) and carefully
slit it long ways with a sharp box knife. Then I placed this
slit hose on the bottom ring on my LP tanks.
This really cuts down on the scuffing of the paint in the
tray and the bottom of the rings so I don't have to paint
quite as often but the hose holds water so the ring
stays wet longer after a rain.
EVERYTHING is a trade off.......
Also, there is a commercial HUGE LP filling station a few
miles from my home. They re-fill my tanks so I also paint
them when they need it. It saves me a few bucks each
time vs trading them in at Wal-mart or Sams or Lowes
or Home Depot. BUT if they were really bad shape, I'd
trade them in and pick a full tank that looked good.
Peace!
Dan & Rita D
Blue Ox WD hitch
Old 01-27-2011, 10:13 AM   #16
itch'n to road trip
campnqueen's Avatar
great photos...thanks!
Jasper Ga.
Old 01-27-2011, 10:14 AM   #17
itch'n to road trip
campnqueen's Avatar
wonderful suggestions Dan... Thanks a bunch.
Paula
Jasper Ga.
Old 01-27-2011, 10:23 AM   #18
MtnGuy's Avatar
When my current cover finally gives up the ghost, I intend to get 1 with the doors.
I leave the cover off of mine during the winter, anyhow. When it gets real cold, I will turn the furnace on low to keep the vinyl floor from cracking, and if we have a power outage I will use the stove for cooking. I am afraid if I have to remove the cover to turn on the propane valves in cold weather, that puppy is going to crack.
