Old 01-23-2011, 04:00 PM   #1
itch'n to road trip
campnqueen's Avatar
Send a message via AIM to campnqueen Send a message via MSN to campnqueen Send a message via Yahoo to campnqueen
Window cutout for propane tank cover
....so we have this white plastic propane tank cover for our trailer.
The problem is.. its hard to remove and it has to be removed in order to turn on the propane gas.
I have seen somewhere... that some folks have cut an oval hole in the top part of the cover in order to reach through and turn on the propane gas and NOT take the cover off.
Has anyone out there done this mod? How difficult was it to cut away the plastic?
2012 Ford F-250 King Ranch Super Crew Cab 4x4 "Mae West"
2014 Work & Play 25ULA "Ula"
Paula Drake, Ken Cooksey, Sunny Delight & Valor
Jasper Ga.
campnqueen is offline   Reply With Quote
Old 01-23-2011, 04:13 PM   #2
MtnGuy's Avatar
My DD and SIL have something like this with access doors on the top: Propane Tank Covers on Sale
Old 01-23-2011, 04:23 PM   #3
itch'n to road trip
campnqueen's Avatar
Mtnguy,
Yes this is what my cover is like... the double 20# tank cover.
I did not see one with a window cut out. Hate to get rid of ours...nothing wrong with them other than the design.
Figured we could fix that.
Jasper Ga.
Old 01-23-2011, 05:16 PM   #4
propane cover
Try to move the tanks closer together.The cover might then be easier to remove.
The Danish Guy is offline   Reply With Quote
Old 01-23-2011, 05:19 PM   #5
itch'n to road trip
campnqueen's Avatar
That's a good idea. I still think I want a window / door to just reach thru and turn propane.
Jasper Ga.
Old 01-23-2011, 06:12 PM   #6
Send a message via Skype™ to scubieman
I would not let tanks be exposed, the tanks may rust in unwanted areas quickly.
2009 Dodge Ram Mega Cab 2500 6.7 cummins
2011 Forest River Cherokee 28BHKS
scubieman is offline   Reply With Quote
Old 01-23-2011, 06:45 PM   #7
MtnGuy's Avatar
Originally Posted by campnqueen View Post
Mtnguy,
The covers that I linked to list them as having "2 secure, easy to open gas valve access doors."
Old 01-23-2011, 06:45 PM   #8
Danimal's Avatar
i wonder if you could mount a acsess door like the ones on the side of the campers
that lock up you water hook ups and electric hook ups
if you have a flat surface in the front
might be a good cheap fix
dan
2005 Dodge Ram
2011 Rockwood 8281SS
Danimal is offline   Reply With Quote
Old 01-24-2011, 07:43 PM   #9
Talking
I make wooden banks with oval cutouts covered with plexiglas so I cut a 5" oval in the front of the cover and put the p-glas inside. Works great! This is after we ran out on a 9* morning in Joplin, MO.
tejano is offline   Reply With Quote
Old 01-24-2011, 08:27 PM   #10
grhodes50's Avatar
My tt came with a tank cover that has an access door. Here's a couple of pics.
It shouldn't be too hard to make something similar in your tank cover.
The only draw back is you can't read the red/green indicator unless you remove the cover.
Name:	Tank Covers Closed.jpg
ID:	4302   Click image for larger version
Name:	Tank Covers Open.jpg
Gary & Trish
2018 Nights Camped - 5
