Old 03-22-2012, 11:58 PM   #11
Would there be any issues with using gray or smoked Lexan instead of tempered glass. The wife and I hate not being able to see out of the frosted door glass.
2011 8314 BSS Rockwood Signature Ultralite
2005 Dodge Ram 2500 Quad-cab SLT
Makoto is offline   Reply With Quote
Old 03-23-2012, 05:07 AM   #12
DAISY BOYKIN's Avatar
I selected the-------
I selected the tempered glass because it does not scratch. The glass I removed is (no see through) also tempered. And you can not apply the tint material to plastic or lexan. The tint material (GILA) instructions said not to use it on lexan or plastic for it will bubble. I didn't believe them, so I tried it anyway. Well they were right, it bubbled like crazy.
Sid, Lois & HRH MISSY Terrible 2s SHIH TZU
2011 ROCKWOOD 8285 WS
2014 F-250 KING RANCH PS/SD/6R140/BFT
DAYS CAMPED 2018 21 DAYS
DAISY BOYKIN is offline   Reply With Quote
Old 03-23-2012, 09:12 AM   #13
To answer the question about the tint breaking the windows, I know on double pain windows putting tint can cause them to break because the heat is reflected from the inside glass and gets trapped between it and the outer pain.
the.wilsons is offline   Reply With Quote
Old 03-30-2012, 01:23 AM   #14
Thanks for this info, I'm going to do this on my rig this summer.
Thank you
Bruce
Bruceh36 is offline   Reply With Quote
Old 03-30-2012, 03:25 AM   #15
Does get hot-----------
The tint I applied to the skylight in the bath causes the glass to get pretty hot. I guess you can consider it a double! The grey glass I installed is not far from the bubble dome on the top of the RV. The reflected heat, I guess is trapped between the tint and dome. I may have to remove the Tint in the bath.
Old 03-30-2012, 07:05 AM   #16
Herk7769's Avatar
Speaking of window glass, I got a real education on what is available from the industry here: GrayGlass - Home
While I think they are wholesalers only, a local glass shop should be able to order and cut what you need.
HAM CALLSIGN - KC3FFW
Old 03-30-2012, 07:36 AM   #17
RonLynnJr's Avatar
Applying tint
I have applied tint to cars before and the best thing I found was to use a hair dryer to remove any wrinkles. That and make sure to remove the backing of the tint...did that once and had it bubble like crazy, lesson learned. Man, the more I read this forum the larger my to-do-list gets.
Ron, Tami, Annette, and Ron III
United States Coast Guard Active Duty
2011 Salem 28BHSS / 2004 Dodge 2500 Cummins
2012 reserved/camped (17/4)
RonLynnJr is offline   Reply With Quote
Old 03-30-2012, 07:50 AM   #18
Herk7769's Avatar
Welcome to my world, Ron...
Old 03-30-2012, 08:26 AM   #19
Chewie's Avatar
It is an "art" to install aftermarket window tint. I hate clear glass and have had my auto windows tinted on every car I've owned. I have it professionally done just because of the results. Curved and rounded glass are very difficult to put a flat sheet of tint on without bubbles and wrinkles. My TT has all flat glass so it's easier. The easiest ways to shrink tint and prefit it is to use a wet bounce dryer sheets to smooth and flatten bubbles while using a hair dryer. Do this on the outside of the window and leave the backing film on until your ready to install tint. Start from the inside and work out. This has yielded me the best results. Search YouTube for videos on how to.
I used to have a really nice motorhome
2016 Jeep Wrangler Unlimited
Chewie is offline   Reply With Quote
Old 03-30-2012, 12:09 PM   #20
trudinator's Avatar
When I mentioned your mod to my DH, he said the very same thing.
2012 Rockwood 8293RKSS
trudinator is offline   Reply With Quote
