Old 07-12-2009, 12:05 PM   #1
The Jolly Mon
NDJollyMon's Avatar
Send a message via Yahoo to NDJollyMon
Winegard Wingman
Anyone use the Winegard Wingman for strengthening DTV signals on the standard Winegard Antenna?
Pete (Jolly Mon)
2018 Wildwood Grand Lodge 42 DLTS
-Seasonal Space, Northern MN.
-2017 Sylvan 8522 LZ LES/115 Merc/Sea Legs
NDJollyMon is offline   Reply With Quote
Old 07-12-2009, 01:30 PM   #2
I've been using it for awhile now and it seems to help out with some of the channels that use to pixelate (some still do but not as often as it use to). The signal is more directional so I find I got to adjust antenna depending on where the station are located and to get the best picture, over all I think it helps some I've tried this at home and different campground that didn't have cable hookup
cma659 is offline   Reply With Quote
Old 07-12-2009, 02:29 PM   #3
I'm using that set up now, and it does improve the digital signal. Before, I was getting digital freezes on some stations in some areas, and I've seen a noticable improvement with the wingman accessory. HOWEVER; if you're contemplating purchasing one of these, go on your roof and check to see if you have room- you'll need about a foot of clearance towards the awning side of your rig when the antenna is in the DOWN position. They are very simple to install, the most you'll need is a pair of pliers. Randy
Old 07-12-2009, 06:20 PM   #4
j2detroit's Avatar
yes we were getting variose types of distorsoin and this cured it we have a seasonal lot 60 miles ne of the twincities and it has worked so well about a dozen other seasonals have also bought and installed them
j2detroit is offline   Reply With Quote
Old 07-12-2009, 07:56 PM   #5
The Jolly Mon
NDJollyMon's Avatar
I already ordered one. Clearance isn't really an issue with me. My antenna never really gets lowered. I'm hoping it stops some of the freeze ups and pixelation interuptions.
I miss analog already!
Pete (Jolly Mon)
Old 07-13-2009, 08:50 AM   #6
bamasurveyor's Avatar
I've used my new wingman once and it did help. I still have to turn the antenna almost every time I change the channel but the picture will improve. and I do pickup more channels at the local campground(at least more PBS and religous programming) Why does Montgomery Alabama need 7 religous channels??? If you aint gonna watch the first 2 or 3....
John
Ted
bamasurveyor is offline   Reply With Quote
Old 07-13-2009, 10:31 PM   #7
The Jolly Mon
NDJollyMon's Avatar
Here's a cool link:
http://www.fcc.gov/mb/engineering/maps/
You can search an address, zip code and find the channels in the area...and the signal strength. Nice.
Pete (Jolly Mon)
Old 09-04-2009, 05:28 PM   #8
The Jolly Mon
NDJollyMon's Avatar
I have it installed, and it helps with my reception VERY WELL! I can now watch most stations without annoying freeze ups! Great product, easy to install.
Pete (Jolly Mon)
Old 09-04-2009, 06:54 PM   #9
Cyber Phrenologist
Radio's Avatar
We have a bunch here in Atlanta, too. Of the selection, I think 2 of them are pretty good. I guess it all goes back to that Founding Father stuff about our basic freedoms, speech, religion, thought and all that. Nobody makes me/prevents me from watching what I want.
I just wish some of the better news organizations would put some 24 hour news stuff up on "on air digital TV" but that would probably annoy the cable operators.
To get back on topic, after I get a job, and before we go on our next trip, I'm going to get a wingman, and some other goodies. Having an understanding of antenna theory I can look at it and tell it will help. But I have to take their word as to how much.
KU4OJ
Admin at www.openroadsradio.net, part of the Social Knowledge network.
"RVing and Amateur Radio served up on the same plate"
2008 (or is it 2009?) Rockwood 8280SS - 2007 F-150
Radio is offline   Reply With Quote
Old 09-04-2009, 08:17 PM   #10
Cyber Phrenologist
Radio's Avatar
Randy
Glad you mentioned that...so I went and checked...I'm good!
All I need now is a job to get toy money....and then no time to camp for going to work.
Sometimes, you can't catch a break.
KU4OJ
