Old 11-02-2008, 05:49 PM   #1
Winterizing the Black Tank Flush
Here is my cheap solution to winterizing the black tank flush, if you have an outside shower.
Go to Lowes and buy a 1/2" MIP to 3/4" Male garden hose adaptor (Watts # A-663). Remove the shower head from the hose and screw in the adaptor. The adaptor then screws into the black tank flush. Turn on the shower spigot and let the pink stuff flow.
Cost $3.42.
John U
2007 Rockwood 8315SS
2014 Silverado 2500HD 6.0L
midnightpumpkin is offline   Reply With Quote
Old 11-02-2008, 08:18 PM   #2
wildwood's Avatar
Nice suggestion, I dont have an outside shower.
I wish i had pumped a bit in mine. I blew out the two I have with air, hope it doesnt get to cold in SC. I had a plastic pump but didnt have it with me. I will put some in next year, hopefully wont have to repair anything. If I go down for a couple days in November I will put some in the lines.
2008 Wildwood LE 29BHBS
wildwood is offline   Reply With Quote
Old 11-02-2008, 08:49 PM   #3
Cyber Phrenologist
Radio's Avatar
That's a great idea!
Also good for rinsing out the tank if you ever got in a situation where there is no city water hose to flush with. And pink stuff could be poured into the black tank flush with a funnel and a short lenth of water hose like comes with an outside water filter if you have no outside shower.
KU4OJ
Admin at www.openroadsradio.net, part of the Social Knowledge network.
"RVing and Amateur Radio served up on the same plate"
2008 (or is it 2009?) Rockwood 8280SS - 2007 F-150
Radio is offline   Reply With Quote
Old 11-03-2008, 07:58 AM   #4
Head Rambler
Great Idea ! Even if you had to add a piece of hose it would work great!
Gotta go campin!
Old 11-03-2008, 01:23 PM   #5
powerboatr's Avatar
your flush is positioned much different from ours
ours is up on the sidewall and has a self drain and a vacum break inside, i dondt think i could put pink in it with it draining out.
cool idea though for flushing the puppy, thanks
Living in the Piney Woods of Texas.
powerboatr is offline   Reply With Quote
black tank, black tank flush
