Old 09-05-2018, 09:37 AM   #1
Wobbly Dinette table
Has anyone modded their dinette table?? Need some ideas!! I saw this one and wanted to know if anyone has installed it..Thanks!!
SNAP 2 Folding Table Base-V-40 from FactoryRVSurplus.com
2019 Wolfpup 18TO
Who went in the way before you, to search you out a place to pitch your tents in, in fire by night, to shew you by what way ye should go, and in a cloud by day.
Deuteronomy 1:33
wolfpup64 is offline   Reply With Quote
Old 09-05-2018, 09:48 AM   #2
Kaadk's Avatar
I'm not familiar with what comes in the Wolf-pup, is the pipe style or the folding style? In our Flagstaff we had the folding style and had to add a couple of braces to eliminate the wobble:
Our Surveyor has the same style table, but it doesn't seem as wobbly as the one in the Flagstaff was. I think that's because of how the legs were orientated to the table top. In the Flagstaff, it was along the short width, so there was a lot of table to support around the pivot. In the Surveyor, it's along the longer length, so not as much pivoting.
Old 09-05-2018, 10:11 AM   #3
Mine has 2 pole mounts and bases are made of plastic..was considering using metal bases and dump the plastic ones
2019 Wolfpup 18TO
Deuteronomy 1:33
Old 09-05-2018, 10:24 AM   #4
Kaadk's Avatar
Sounds like a good plan.
Old 09-05-2018, 10:25 AM   #5
rk06382's Avatar
Quote below from FR3 Pictures of Mods: Table legs
Originally Posted by rk06382 View Post
I replaced the Dinette table legs with Sequoia table legs. I was able to purchase local for less than Amazon but included link to clarify.
Amazon: 27'' Sequoia Table Leg
Attachment 172276Attachment 172275
Attachment 172277Attachment 172278
We travel with our son and my DW did not like stepping on the old table base when she sits in the back. She likes to go barefoot in the RV.
The Sequoia table legs locked the base of the legs. This stabilize the table legs.
Robert
2018 FR3 28DS
Samlex EVO-2212 Inverter/Charger | 400ah Battle Born LiFePO4 | Victron BMV-712 & MPPT 100/50 | 1KW Renogy Solar | Fan-Tastic Fans | Blue Ox TruCenter | Dometic 320 | SnapPads
Retired: Alaska Army NG
rk06382 is offline   Reply With Quote
Old 09-05-2018, 10:58 AM   #6
ColoradoRick's Avatar
Great ideas! I just had our wobbly table upside down so I could tighten all the screws but didn't find any very loose.
Rick & Karen
(Retired USAF, MSgt)
Monument, Colorado
8-year Travel Trailer RVers
2013 Forest River Rockwood Ultra-Lite 2904SS
2014 Toyota Tundra Maxcrew SR-5 TRD 4x4 (with Firestone airbags in the rear)
ColoradoRick is offline   Reply With Quote
Old 09-12-2018, 05:57 PM   #7
Kasual Kamper
That is exactly the problem we have in our Flagstaff! The table has too much surface area to adequately support it. Kaadk, can you provide more details on the braces you cite above? Where did you get them?
Current: 2013 Flagstaff MicroLite 21DS
Past: 2000 Fleetwood Mallard 19N
TV: 2013 Nissan Pathfinder SL 4x4
JayArras is offline   Reply With Quote
Old 09-12-2018, 06:27 PM   #8
SecretSquirrel's Avatar
I have the same style and was very wobbly. Turns out the bases were screwed through the carpet and were barely into the wood below. Used a utility knife and cut all around the bases. Removed the bases and the carpet below that was just cut out. Reinstalled the bases directly to the wood. Don't over tighten the screws, just very snug. Much, much better now.
_________________________
Crusader 337QBH
2019 F350 6.7L DRW CC LB 4x4 Lariat
B&W Companion 20K for OEM pucks.
SecretSquirrel is offline   Reply With Quote
Old 09-12-2018, 07:44 PM   #9
Kasual Kamper
Your style is different because this table is freestanding and just rests on the carpet.
Old 09-12-2018, 08:59 PM   #10
Kaadk's Avatar
I got them from “Father In Law’s Shop”
They’re just pieces of flat stock he had on hand that he cut to size for me, and then screwed them on using some self tapping bolts.
