Old 05-08-2014, 08:59 PM   #11
Kaadk's Avatar
Originally Posted by 5erDriver View Post
We don't use or plan to use our table for extra sleeping room as it becomes a bed too. What I did was simply use a fairly long angle bracket from the framing connection section in Home Depot. A Simpson product. Sprayed it black and screwed it into the wall with short screws and up into the table. Solid as a rock.
Doesn't work so well on the U-shaped dinettes.
There's no use crying over spilt milk, unless it's on your keyboard.
Old 05-08-2014, 09:17 PM   #12
VinceU's Avatar
Originally Posted by Timex View Post
I need to replace my mechanism on my table and want to put 2 pedestals. My dinette is in a slideout, what is under the floor? Will I be able to put at least a 1/2" screw in the floor to mount the base of the pedestal?
P
The floor is a lot heavier than the wall in sheet thickness. The wall is a sheet of luan backed by foam, the floor is at least 3/8"-1/2" MBF. Pilot drill your holes, you'll be fine.
Old 05-08-2014, 09:27 PM   #13
Timex's Avatar
What is under that incase I drill/screw past the floor? I'd at least want a 1/2" screw.
Timex is offline   Reply With Quote
Old 05-08-2014, 09:40 PM   #14
VinceU's Avatar
Not for certain in your unit, but at least a thin layer of insulation and some sort of fiberglass cloth to keep everthing in place. You don't want screws protruding, seal damage can result. Take an ice pick with slide open and gently probe from underside up. The GT has at least 1/2" flooring plus insulation. Base your screw length on your findings. Believe most sides when retracted can be measured under the carpet flaps for floor thickness.
Old 05-08-2014, 09:45 PM   #15
Timex's Avatar
Maybe I can do some probing with the slide in and look under the floor. Thanks for the help!
Old 05-08-2014, 09:55 PM   #16
nuisance's Avatar
We are thinking of putting a 3rd leg on ours. and a second set smaller to use when the grand children come with us. Right now we have 1 -18yr old with and infant, 1 - 9 year old, 2 - 8 years olds, 1 - 7 year old, 1- 4 year old, 1 - 2 year old and soon adding 1 - 11 year old, 1 more 7 year old and another 4 year old and 1 on the way.
[COLOR="Red"]Al and Deb
Sugar and Anna Belle
2016 Toyota Tundra
2011 Greywolf 26rl
nuisance is offline   Reply With Quote
Old 05-08-2014, 09:57 PM   #17
Kaadk's Avatar
That's a lot of kids to pack around one table.
Old 05-09-2014, 03:13 PM   #18
Timex's Avatar
I've seen 8 people at an rv table before but not 12!
You're going to need more table to go with those legs!
Old 05-20-2014, 04:56 PM   #19
Timex's Avatar
Here's what I had
My folding mechanism bit the dust on the last trip. WORD OF ADVICE: Fold the table down to the bed position when traveling.
So I took it off the bottom and attached pedestal bases to the bottom side of the table. Attached .5" plywood with 1" screws and the bases with 1" screws. The pieces on each side were already on and the middle piece is a scrap piece I had that fit just perfect. I know it ain't pretty but who looks under a table!
ID:	52876   Click image for larger version
Old 05-20-2014, 05:09 PM   #20
Timex's Avatar
Here's what I got
The first pic is what it looks like under the carpet. Screwed the bases to the floor with .5" screws. I was afraid to use any longer in case it went thru the plywood. The legs are 29.5". The original mechanism was 27.5" . A little higher but it will make the food closer to it's target! A lot steadier than what I had, we'll see how it holds up. I'll be sure and take it down for travel.
ID:	52878   Click image for larger version
ID:	52879   Click image for larger version
ID:	52880   Click image for larger version
