Old 02-28-2016, 12:36 PM   #1
Wolf pup 16bhs/Furrion DV3100
Just purchased our first TT. It came with the Furrion DV3100 which is a stereo and DVD player. TT came with the roof mounted HD antenna which uses coax. There are coax outlets inside and one outside so I assumed the DVD would also run through these outlets. I assumed wrong. After trying everything I knew to do to get DVD picture to tv I finally pulled the Furrion out and sure enough there were the RCA cables for the DVD player....hooked to nothing.
My first question is why Forest River put the DVD player in and not put outlets to be able to use it like they did with the coax. To use it in the current configuration I'd have to run RCA cable across the TT to use it inside and out the door to use it outside.
Second question. Before I go to my local RV shop and/or mobile audio/video shop, has anyone else had this issue? If so what was your solution?
Sfogle is offline   Reply With Quote
Old 02-28-2016, 12:41 PM   #2
rmac04401's Avatar
There are multiple connections on the back. Mine was hooked up wrong. They had it hooked to wrong connections. Mine did have rca wires. The three that have like plastic caps on them is the ones I had to connect them too. Once I moved connections not outdoor and indoor tv
2016 Grey Wolf 26rr
2005 Honda VTX 1300
2012 Ram 2500 Crew cab 6.5 bed
5.7L Hemi, 3:73 Rear
Ron & Shirley (Empty Nesters)
rmac04401 is online now   Reply With Quote
Old 02-28-2016, 12:55 PM   #3
Yes mine also have the plastic caps but I see nothing to plug them in to
Old 02-28-2016, 04:07 PM   #4
rmac04401's Avatar
Should be wired coming in from wall on outside wall and wires coming from top. Click image for larger version
Name:	ImageUploadedByForest River Forums1456697188.274691.jpg
ID:	100664Click image for larger version
Name:	ImageUploadedByForest River Forums1456697220.055963.jpg
If you have no hole in wall like mine they probably did not run the wires.
2016 Grey Wolf 26rr
2005 Honda VTX 1300
Old 02-28-2016, 04:24 PM   #5
Are there wires coming out of the hole that you plugged the RCA wires from the DVD in to?
Old 02-29-2016, 05:54 AM   #6
rmac04401's Avatar
Yes. I would have to retrace to figure out what I did last August. But I believe I traced wires coming from walls that go out to outside tv. I would have to pull the DVDs/receiver again to be exact.
2016 Grey Wolf 26rr
2005 Honda VTX 1300
Old 02-29-2016, 05:57 AM   #7
rmac04401's Avatar
You should have a plate with female connections that your tv plugs into take that plate off to see if you have wires behind it. Those wires should be coming out somewhere close to the DVDs.
2016 Grey Wolf 26rr
2005 Honda VTX 1300
Old 02-29-2016, 08:08 AM   #8
Only plates I have are coax plates inside and out. It's becoming apparent that the wires were never ran. Thanks for your help!
Old 02-29-2016, 08:38 AM   #9
rmac04401's Avatar
You should have four plates close to main tv mount. A coaxle, antenna booster, electric plug, and audio video. All for your TV to plug into.
2016 Grey Wolf 26rr
2005 Honda VTX 1300
Old 02-29-2016, 08:56 AM   #10
rmac04401's Avatar
I just looked at your unit on Internet. It looked like that model was not set up for DVD. I would call your dealer to find out. From pictures and 360 it looks like you just have an atennea booster with a coaxle. Is that unit just a CD player and not a DVD?
2016 Grey Wolf 26rr
2005 Honda VTX 1300
