Old 11-08-2011, 04:08 PM   #11
RubenZ's Avatar
Thanks for input guys. My wife is just super paranoid about propane. She's even nervous using Water heater. So I was trying to make her more at ease with electric heater.
__________________________________
Ruben Zamora
2007 Silverado 2500HD 4x4 Dmax/Allison, 4" Exhaust-no cat-no muffler
2012 Palomino Puma 23FB
RubenZ is offline   Reply With Quote
Old 11-08-2011, 04:21 PM   #12
MrT
MrT's Avatar
Originally Posted by dretired View Post
get a vornado whole room heater $60..and works great
+1 on that. We use one or two supplemental ceramic heaters at the extremes of the season to help offset propane use. Some of the ones we own are a bit noisy for nighttime use, though.
2017 Cedar Creek 38CK Hathaway Edition
2015 Ford F-350 6.7 CC 4x4
B&W RVK3300
Full-timing since 5/2/2016. Roam Sweet Home.
FROG Int'l Rallies: 2012-2017
MrT is offline   Reply With Quote
Old 11-08-2011, 06:26 PM   #13
Jeep4Two's Avatar
Originally Posted by RubenZ
Our Trailer is 23ft or slighter bigger. It seems like those heat pumps are ceiling mounted. Our Furnace is mounted under the jacknife Sofa and A/C is ceiling mounted obviously with ducts. I just wish I could utilize the existing space for current furnace and take that out and mount something electric in there.
My cool at heat pump/ac unit is mounted under the sofa in the A126.
I do however agree that keeping a gas option is a good idea. We only plan on using the LP furnace when boonedocking or when the heat pump isn't sufficient (although we are really leaning to a ceramic space heater for those really cold nights instead of gas).
Jeep4Two
2011 FR Rockwood Premiere A126 Hard Side
TV=2011 Jeep Wrangler Sahara 2 Dr
Reese 66065 WDH, Curt WDH Shank #17120
Prodigy P2 Brake Controller, Mopar 7-pin Harness
B&M Transmission Cooler (#70268)
Jeep4Two is offline   Reply With Quote
Old 11-08-2011, 06:33 PM   #14
JAYCO Representative
Wildcat Chris's Avatar
Buy any unit with a built-in fireplace... there's your electric heater (plus ambiance)!
Wildcat Chris is offline   Reply With Quote
Old 11-08-2011, 09:29 PM   #15
jimh's Avatar
you can also add a fireplace from sams club for abt $80. can enjoy the fireplace w/o heat if u so desire. no wood, propane, or kerosene. two heat settings: 700w and 1500w. heater is underneath; rest of the unit runs cool.
jimh is offline   Reply With Quote
Old 11-08-2011, 09:35 PM   #16
Rugged Brown's Avatar
This is what I did for $25
ID:	9042   Click image for larger version
ID:	9043   Click image for larger version
ID:	9044   Click image for larger version
Terry/Bernadette
Lily the Yorkie
2015 Dodge Ram Sport 1500
2015 Crossroads Zinger ZT28BH
Rugged Brown is offline   Reply With Quote
Old 11-08-2011, 09:42 PM   #17
caper's Avatar
Just purchased an electric fireplace from wally world for $70. Looks like a real fire and has a 1250 watt heater on it. Weight is only 18 lbs.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
Old 11-08-2011, 09:44 PM   #18
Dave_Monica's Avatar
Nice job Terry...well done!
Dave
Old 11-08-2011, 09:47 PM   #19
fast murray's Avatar
We dry-camped for 3 nights in TN a couple of weeks ago where it was getting down to 33 degrees. I had 1 honda 2000 running the camper and another running an edenpure quartz heater. I didn't really like 2nd generator sucking gas but I'm glad I had it. I also didn't like the heater sitting on the floor as it's bulky, but again, I'm glad I had it. That setup kept it toasty warm without running the furnace at all.
fast murray is offline   Reply With Quote
Old 11-09-2011, 05:57 AM   #20
daverain's Avatar
Just a thought, depending on what roof top a/c you have, you can buy a 5600 btu heat strip for it, we use ours for milder nights, works well, use the fan on manual, provides extra outside noise abatement. Our a/c is a dometic, not sure if you can get one for a carrier unit.
Dave and Rainy
daverain is offline   Reply With Quote
