Old 04-30-2015, 04:31 AM   #11
If you were plugged in you will still have 12 volts from the converter even with the battery disconnected.
2015 Windjammer 2618W, Reese Stright-Line Hitch.
2013 Chevy 2500HD LTZ Duramax/Allison, Stock
Just Me & The Wife
Proud To Be An American
Max Windjammer is offline   Reply With Quote
Old 04-30-2015, 09:19 PM   #12
WFD
Bingo!...That's what it is...I was plugged in to power at the house...Silly me...I just assumed that disconnecting the battery would have prevented that... I guess it wasn't even necessary for me to disconnect the battery.
2016 Chevy Silverado 2500 Duramax
2016 Rockwood 8289WS, Diamond Pkg.
WFD is offline   Reply With Quote
Old 05-01-2015, 02:27 AM   #13
If you were unplugged you would still have to disconnect the battery or shut off the battery switch (if equipped) . There are also fuses in the panel but unplugging and disconnecting the battery is the easiest way to do the job.Shorting the wires can damage the board in the AC.
Just Me & The Wife
Old 05-01-2015, 06:32 AM   #14
Some domestic digital thermostats have what I consider a major flaw in them because they don't work below 32 degrees or so. Below that temperature THEY WILL NOT TURN ON YOUR FURNACE!
Hard to believe anyone would make something like that!! (Honeywell)
2007 Chevy Couchman Freeloader
klspahr is offline   Reply With Quote
thermostat
