11-23-2014, 01:20 PM
Yada wireless camera from Costco
Costco has a Yada wireless backup camera with a 5" display. Starting tomorrow it's $99, $20 off. I'm thinking of giving it a try. I'll probably tie it to the running lights so I can use it as a rear view camera. If it doesn't work I can return it.
Jerry
2007 Surveyor SV 230
2013 F150 Ecoboost
11-23-2014, 04:32 PM
Azjerry- let me know how it works out for you. My problem may be the range as my trailer alone is at 31'.
2014 Stealth Evo 2850 "Woodstock"
2011 Toyota Tundra Rock Crawler TRD 5.7 "Clifford"
Just glad to get away
11-23-2014, 04:50 PM
I checked the reviews for a Yada camera with a 4" display on Amazon. They were mostly positive. Many said it worked fine with trailers of various sizes while a few others said it didn't even work on the length of their vehicle.
Jerry
2013 F150 Ecoboost
12-28-2014, 07:07 PM
Finally got this installed. Picture is clear. I haven't tried it out on a trip yet but did drive the TV several houses away before the signal was lost. Given that range I believe it should work well while under way.
Jerry
2013 F150 Ecoboost
01-03-2015, 12:49 PM
And a final report on my Yada camera from Costco. Got back from our New Year's trip and am happy to report that the camera and monitor worked just fine. Absolutely no interference or breakup of the picture.
Jerry
2013 F150 Ecoboost
01-21-2015, 04:39 PM
I've read on the Yada spec sheet online: "Maximum Signal Range: 30 feet/10Metres" for this camera/monitor setup. are you getting more? I'm thinking I need a range of at least 60ft.
2015 Rockwood Windjammer 3029W Diamond Package
2014 RAM 2500 Laramie Longhorn 4 x 4
6.4 Hemi 410 HP, 410 Rear Axle
01-21-2015, 08:29 PM
I was worried about the range as well but figured that since it came from Costco I could return it.
After installation on the trailer I drove the truck about two houses away before the picture started to break up. The picture was rock steady when actually towing. The trailer is about 25 feet and the truck is a 5.5 foot crew cab.
Jerry
2013 F150 Ecoboost
02-21-2015, 06:57 PM
azjerry, Your camera is the Yada Wireless Backup Camera with 5” Dash Monitor correct? It worked two houses away, then I should work on the back of a 35 ft TT with monitor in the cab with no problem. Was concerned on the advertised 50 ft range. Does the camera hardwired to 12 volt? I searched the internet and it looks like they are only available at Costco. Can anyone order online from them or is it for members with a membership only?
thank
02-22-2015, 12:45 AM
Yes, it's the 5 inch version. I found smaller version online, Amazon I think. I hardwired the camera to the trailer running lights which are on when driving my truck. As far as I know you have to be a member.
There might be a problem with the metal siding on a trailer interfering with the signal. My trailer has the fiberglass laminated walls which shouldn't be a problem. Your mileage may vary.
Jerry
2013 F150 Ecoboost
05-11-2019, 06:56 PM
How did you access the running lights for power? It looks like they’re sealed to me.
05-12-2019, 01:23 AM
Since the last post here was over 4 years ago and azjerry hasn't posted for 3 years, you will probably get a quicker response by PMing him.
05-12-2019, 09:53 AM
Thanks, I’ll try that.
BillW
05-12-2019, 10:18 AM
Georgia Rally Coordinator
BillW
He may not be on here anymore last time visited forum over 2 years ago. Later RJD
Traded 2015 30WRLIKS V-Lite
Days camped 2019 62
