Closed Thread
Old 12-03-2015, 03:05 AM   #301
Witch Doctor's Avatar
Originally Posted by MillerTime View Post
Why do you think its photo shopped? Looks like the same decal that im posting, with elongated black ends on th X. The vinyl on vehicle decals are pretty good and they will strech quite a bit when trying to remove them and or if you tried tearing them.
I mean if you just trying joke around thats fine. If it was photo shopped, then that editor knew an awful lot about collision dynamics and payed a lot of attention to all the other areas and background detail that show that this was a front-to-rear side swipe and they also knew that aluminum would rip at a much greater rate than steel. Doesn't sound like the kinda knowledge a CG guy would know. I know wrecks, but im no CG guy.
(The details in this photo lead me to believe this was a legitimate wreck)
MillerTime, What are they going to do to get these cars repaired most body shops can't weld aluminum. At least not the ones by me in Southside Virginia? This could be a nightmare for someone. Just a question.
Coachmen M/H
Concord
2018 / 300 DSC
Witch Doctor is online now
Old 12-03-2015, 03:53 AM   #302
Rumor has it Ford is going to change the body material to pizza grade Little Caesars boxes.
Mr Havercamp is offline
Old 12-03-2015, 05:28 AM   #303
drittal's Avatar
Originally Posted by A32Deuce View Post
Just converted the Dart from auto to stick. Haven't been to many races this year. When it was auto, would hang front tires till after 2nd, gear! 8.28 @ 163. Barton builds the engines.
That's motivating! Wow. When I built my 440, I went for slightly more than stock Magnum specs.
.040 over
Lunatic Voodoo 60304 276/284. .513/.533
MP template ported stock heads
Edelbrock CH4B intake <--old school but still makes good power and low enough to clear hood.
Street Demon 750
8 3/4" sure grip with 3.23.
drittal is offline
Old 12-03-2015, 06:10 AM   #304
Left Coast
I see a second business in his future....sell'n welders and alum. wire spools and fill'n gas bottles
bob caldwell is offline
Old 12-03-2015, 07:13 AM   #305
A32Deuce's Avatar
Sounds like it. GM is jumping on the alum bodys next. Wont take long before Ram makes the jump. So many high end cars with alum, cant see what all the problem is. Looking forward to the rally in NC. Lots to talk about!
A32Deuce is offline
Old 12-03-2015, 07:17 AM   #306
Left Coast
That's in the order of the way they rust away!
Old 12-03-2015, 07:24 AM   #307
A32Deuce's Avatar
I don't know. Mine is a 2001 and just has a small rust spot and my pick-up came out of Florida.
A32Deuce is offline
Old 12-03-2015, 07:29 AM   #308
Sounds like a coffee subject at Bob's every morning with a little Brandy to cut the cold wind. Or hot air....
Coachmen M/H
Concord
2018 / 300 DSC
Old 12-03-2015, 07:32 AM   #309
A32Deuce's Avatar
X2!
A32Deuce is offline
Old 12-03-2015, 07:45 AM   #310
Oklahoma Proud
MillerTime's Avatar
Its a huge nightmare for everyone. I dont think there are much more than half a dozen shops in the okc metro that could do the work, and that's out of probably 100 or so shops.
I see a lot of unhappy ford owners in the future and possibly a huge lawsuit for Ford after there are so many people truckless with trucks waiting on repair.
We were taught in 2015 f150 school, that you have to use a welder that is capable of synergic pulsed spray transfer using AA5554 wire that is 1.2mm in diameter. You can not use a tig. You will potentially fry all the computers from the high frequency of a tig welder.
We are supposed to use alot of panel bonding adhesive on the panels as well as riveting them on with self piercing rivets(spr), flow drill screws, solid rivets. etc.
Galvanic corrosion is a big problem (white rust) so you cant use bolts more than once unless they come out with a coating to recoat the bolts. Ford recommends replacement though. Our instructor didnt even know how it was going to work with the parts being panel bonded and then welded ar the seams, with the way aluminum transfers heat.
Heres a couple pics of a self piercing rivet gun (used to remove and install rivets) and the SPRs (they look like little buttons) and a couple of the flow drill screws
ID:	95463   Click image for larger version
ID:	95464   Click image for larger version
ID:	95465   Click image for larger version
ID:	95466   Click image for larger version
MillerTime is offline
Closed Thread
ford
