Old 05-01-2013, 10:44 AM   #11
Anacortesians
On a serious note for a moment - I once went to one of those quick-change places. They drained the sump, put the plug back in, new filter on, then put 5 quarts of engine oil into the transmission.
Five miles later, the engine threw a rod through the oil pan. The transmission was acting oddly, too. They ended up buying the car and I got another one with the money.
Frank and Eileen
No longer RVers or FR owners
Old 05-01-2013, 05:15 PM   #12
Another rat in the race
jar3316's Avatar
Always check the oil before leaving the place, it ticks off the oil jockey. but your safe and he has a little mental jab to double check every car, or at least that's what a properly functioning brain would do.
My whole industry is based on the customer double checking your work and as the manufacturer i make darn sure they never have anything to say, other than thanks.
but I do change my own oil and it does cost me the same as the box store but I get to use full syn, good filter, and I view it as therapy and education for my kids.
I skip the beer though, a buddy was so hammered once he left a socket or bolt (not sure which he wouldn't say) in the cylinder when he closed up his engine and after replacing the block, piston, head and valves; if there is drinking while working on cars there is always a designated inspector.
A rainy day camping is better than any sunny day at work
2004 F250 V10 SD Xcab 2011 Wildwood T26BHXL
jar3316 is offline   Reply With Quote
Old 05-03-2013, 01:25 PM   #13
Arefbee's Avatar
I made two mistakes on one oil change. First I did not realize the O ring from the old filter was still on the motor when I put the new filter on.
Next, did not test drive because DW had to leave and needed the car.
Apparently two O rings are NOT better than one.
The phone rang 10 minutes after she left. I followed the trail of synthetic two miles to where motor had given up.
Filter $5
Oil $30
Motor $700
Since then Jiffy-Lube...
Yet I do still do my own brakes.
2011 PrimeTime Tracer 2600rls
2001 GMC Yukon XL 2500, 6.0L 4.10:1 axle ratio
Nights camping 2014 - 17
2013 - 15
Arefbee is offline   Reply With Quote
Old 05-03-2013, 02:12 PM   #14
QCCowboy's Avatar
There is so much truth to this. Perhaps one could add
-forget what overtightening can do
-strip out oil pan drain bolt
-Get oversized self-tapper so that you can get by for a bit
-two more beers because you are fruatrated
-Put self tapper in crooked (beer is getting to you now)
-wind up having to drop and replace the lower half of the oil pan
to the list here.
Or was that just me?
Jack of all trades - Master of none
2012 F350 CC DRW - 6.7L PSD
2014 Sabre 36QBOK
QCCowboy is offline   Reply With Quote
Old 05-03-2013, 02:23 PM   #15
B47
Filter $5
Oil $30
Motor $700
When I used to change my oil myself, the Fram oil filter box always contained a warning to make certain the removed oil filter "O" ring was not still in the housing before installing the new filter.
B47 is online now   Reply With Quote
Old 05-03-2013, 02:28 PM   #16
Arefbee's Avatar
Yep, I remember reading that a long time ago, but after doing them without issue for a dozen years or so I stopped reading the box.
I think I should have just had a beer instead...
2013 - 15
Old 05-03-2013, 02:32 PM   #17
B47
Or maybe you should continue reading the box before having a beer
My personal experience with this is that the "O" ring came out with the filter more often than not.
Old 05-03-2013, 09:58 PM   #18
Anacortesians
Most US cars have the oil seal bonded to the screw-on filter body. My old 1968 UK Ford Cortina had the older-style metal bowl with an element inside. On one oil change, the tech left the old seal inside the housing. 400 miles later the engine was toast.
I pulled it out and rebuilt it, which went quite well. Before finishing up, I realised that the 1600 Pinto was the same basic engine, so I went to my local Ford dealer and bought the Pinto 1600 oil filter mounting and its spin-on cartridge.
No more screw-ups for several years, until the alternator blew itself up just before we were to relocate from Tidewater VA to Seattle. I planned to flat-tow the Cortina behind our Mercury wagon since it couldn't be driven.
All went well until I made a tight turn in a motel parking lot in Bozeman, MT and snapped off the bracket to which the towing system was attached.
We left the car at the airport and drove to Seattle. I flew back a couple of weeks later with a new alternator and installed it. About 100 miles from Bozeman, I started getting odd jerks in the transmission. Eventually, the transmission seized up. DW came and resued me from Moses Lake and we towed the Cortina home. In the first couple of miles, it became obvious that the transmission was in trouble, so I disconnected the drive shaft.
DW wasn't comfortable towing, so when we got to the top of Snoqualmie Pass, she wanted to dump the car. In the end, I got her to push the totally dead Cortina to start it down the pass. I made about 85 mph on the way down and actually passed several other vehicles, despite being totally "dead-stick". We re-attached the tow just east of North Bend and got the Cortina home. I pulled the gearbox and had it re-built.
It turned out that, despite "general knowledge' about stick-shift transmissions being good to be towed without a disconnect, that particular Ford box had its lubrication pump driven by the input shaft. It was a major achivement that it got from VA to MT without seizing up!
If I'd known how much trouble it was going to be, I'd have set fire to the SOB in Virginia!
Frank and Eileen
Old 05-07-2013, 11:33 PM   #19
Capsfloyd's Avatar
Dallas dodge sells 4 oil changes for 52.00
My hemi holds 8 qts of oil ????
2009 Rambox crew cab
2012 831 Flagstaff RKSS
2010 jeep Liberty
2010 Harley Davidson Ultra Classic
Capsfloyd is offline   Reply With Quote
