Old 10-09-2013, 07:34 AM   #61
Director, FROG
F.R.O.G.'s Avatar
Originally Posted by OldCoot View Post
If you stop and think...
OC, that's where your argument falls apart. Stopping and thinking is a pretty tall order for most of us when we run into a design "problem."
Bob Byrne
Director, Forest River Owners' Group (FROG)
frog@forestriverinc.com
www.forestriverfrog.com
F.R.O.G. is offline   Reply With Quote
Old 10-09-2013, 05:11 PM   #62
phat phrog stunt crew
Originally Posted by Cowracer View Post
No. its because speed (and cost) of assembly rules the roost in automotive plants. You design a system that was 3 parts that had to be bolted together and is now two parts which saves 6 seconds of assembly time and 37 cents in cost, you will get a nice letter of praise in your file and bonus, and a dinner out with the wife at a expensive restaurant on the company nickle.
Design something that makes it easier on the owner to service but costs an extra 15 seconds on the line to assemble, and you would get career counseling.
Tim
save 6 seconds and 37 cents so they can make it up on the back end
first remove positive battery cable from battery. Then remove front passenger tire, then remove strut and hub, then remove cv axle undo two mounting bolts from bottom, once this is done access to three mounting bracket bolts. to remove mounting bracket then slide alternator btwn frame and engine and replace, have fun this takes avg 4-5 hours!
i found out that if you take out the oil filter u can get to the bolts with easy access. it beats taking of the drive shaft. once the bracket is off you can take it out from the top. it would be easier if you unbolt the tension assembly. it took me about 2 hours to do all this and put back together. $20 extra bucks for the oil beats the extra hours i would have to put into working on the car. have fun
OOOOOOOORRRRRRRRR,,,,,,,,
It is possible to remove it from the top of the engine. I know this becasue i just accomplished this in under 3 hours. Start to finish with a coffee break in between. If you want to know exactly how i did it feel free to email me atomic_aura@hotmail.com 03 ford escape v6
3 hrs for an altenatar swap? remove front wheel and hub/axle assembly? where again is the engineer who designed this? i understand the packaging deal, but this is a service item, most likely to go out while you still own the car (thats out of warrenty).
please bring engineer head on platter. doesnt even have to be the good stuff either
dwaynerz is offline   Reply With Quote
Old 10-09-2013, 05:51 PM   #63
Look on the bright side, if you folks didn't have engineers to gripe about, someone else would have to take the heat about something else.
Old 10-09-2013, 06:22 PM   #64
B47
Sort of like saying if you didn't have Turbs to pick on, someone else would be your subject.
Old 10-09-2013, 06:26 PM   #65
TURBS's Avatar
Oh double snap!
Old 10-09-2013, 06:39 PM   #66
Not at all. FT Turbs deserves and expects it.
Old 10-10-2013, 12:04 AM   #67
Just remember - if there weren't engineers, we'd all still be sitting around campfires chipping arrowheads!
2011 Traverse LT, 3.6L, FWD
Old 10-11-2013, 09:40 AM   #68
VinceU's Avatar
Mem, the engineer's job is to to envision, package and out the door for 13K! Remember the Clhevy Vega, had to drop rear motor mounts to change rear plugs. Maintenance is a future problem.......
Old 10-11-2013, 09:48 AM   #69
hkreck's Avatar
Just think most Engineer's went to party schools where they drank more than they studied.
Henry & Tena
2013 Solera 24S
The Great Escape
hkreck is offline   Reply With Quote
Old 10-11-2013, 10:48 AM   #70
B47
I remember the Vega thing - if I'm not mistaken,they weren't the only vehicle that required you to do that or some other thing to replace routine components.
