Old 09-24-2014, 12:48 PM   #11
I ran a 13.5K a/c on it's own 15A plug with no problems. A 13.5K only draws like 12.8 amps, and with the cycling of the compressor it shouldn't ever cause a problem IMHO.
Old 09-24-2014, 01:12 PM   #12
jonrjen's Avatar
You could also install a soft start kit on the compressor to lighten the start up load which keeps your max amp draw down in line with the running amps.
I had also made up a short extension cord that had the 20 amp female end on one side and a 15 amp male end on the other for being able to use the 20 amp line on a 15 amp outlet. While it is not the recommended way to do things, it did work the few times I needed it.
2013 Ford F350 FX4 4x4 PSD
2013 Wildcat 353LS
2015 Day/Nights Camped 5
2014 Day/Nights Camped 29
jonrjen is offline   Reply With Quote
Old 09-24-2014, 07:00 PM   #13
AquaMan's Avatar
I can so the same, but the problem comes when the campground voltage drops, and now you're drawing a full 15amps. Then add to that a typical smaller gauge 15 amp cord and something is liable to get hot. Take all risk out and do the 30amp hookup.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 7
AquaMan is online now   Reply With Quote
Old 09-28-2014, 09:18 PM   #14
Just Love to Camp
TheFordes's Avatar
We installed a third in our garage with a heat strip. 30amp plug. Ran the channel for the cord down the wall after fishing it across the ceiling. Put a twist and lock connection. I can take pictures if you would like but it will be a few days
Camped 54 Night 2012
XLR Thunderbolt 386*12
"Bertha The LeadSled" is her name
2012 F450
Virginia
TheFordes is offline   Reply With Quote
Old 09-29-2014, 06:20 AM   #15
Would like to see pictures if you can provide them
mje000 is offline   Reply With Quote
Old 09-29-2014, 07:33 AM   #16
I ran 10Ga. wire to from my junction box I installed under the camper to the A/C unit. And a 12ga. extension cord to the unit. The only thing that was rated at 15A was the plugs I used on the ends. I compared the dimensions of the 15A plug to the 20A plug my local hardware store sells and found no difference in thickness or width. Only difference I could find was one of the conductors was oriented sideways.
