Old 09-24-2014, 09:47 AM   #1
3rd A/C in garage
I have 2014 40X12HP and would like to install a 3rd AC in the Garage can anyone give me some advice on if possible and how to do?
mje000 is offline   Reply With Quote
Old 09-24-2014, 10:03 AM   #2
AquaMan's Avatar
Most that have added a 3rd AC unit, have wired in a seperate 30amp outside receptacle just for the AC unit itself. Not sure how you would go about wiring it in your TH, but where there's a will, there's a way.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 7
Old 09-24-2014, 10:15 AM   #3
jonrjen's Avatar
Easiest way is to have the A/C mounted then have the wiring run down an interior wall on the curb side (IE: same side as your other hook ups). Your choice then is to either run it through the wall to an exterior receptacle where you can plug in an extension cord from the receptacle to the 20amp power supply at the rv parks power supply.
You don't need to run or wire it for 30amp, but the new standard for a 13.5 or 15K roof a/c is 20amp power.
2013 Ford F350 FX4 4x4 PSD
2013 Wildcat 353LS
2015 Day/Nights Camped 5
2014 Day/Nights Camped 29
jonrjen is offline   Reply With Quote
Old 09-24-2014, 10:54 AM   #4
AquaMan's Avatar
The only downside I see with wiring it for 20amp, is that many pedestals have 50/30/15, and not a 20amp plug. You could use an adapter to draw power from the 30 with a 20amp cord, but for the same money (possibly cheaper) you can run 30amp service and cord, and have power to spare inside.
Old 09-24-2014, 11:02 AM   #5
Kaadk's Avatar
X2.
That was my concern as well when I read the recommendation for a 20A. I haven't seen much of them in the campgrounds I stay at. Just 15's (when they're present.)
Besides, with a 30, you'd be able to use a 30A surge guard or PI or something to protect that nice, new, shiny AC that gets added.
The surest way to lose is to play Marco Polo with a ventriloquist.
Old 09-24-2014, 11:39 AM   #6
jonrjen's Avatar
Actually if you look closely you will find that most RV parks are wired for 50/30/20 amp service. A 20amp plug in looks almost like a 15amp with one little extended slot that delivers the extra power. If you only need 15amp service then you can plug directly into a 20amp circuit only receiving 15amps of power.
2013 Wildcat 353LS
Old 09-24-2014, 11:41 AM   #7
Kaadk's Avatar
Yes, but you can't plug a 20A plug into a 15A outlet for those parks that only provide 15.
Old 09-24-2014, 11:54 AM   #8
ironj's Avatar
im curious how this works on say a new xlr ordered with the 3rd ac and "energy management system" as we are about to get a new unit and I want as much a/c capacity as humanly possible!! LOL
2015 F350 Platinum Fx4 6.7 Diesel Dually. B&W turnover, B&W Companion, air bags and wireless controller.
2015 Heartland Road Warrior 420 Rt
2012 f250 Fx4 6.7 Diesel crew cab tinted n tuned
2012 lacrosse 318bhs touring- sold
ironj is offline   Reply With Quote
Old 09-24-2014, 12:00 PM   #9
AquaMan's Avatar
I'm guessing the energy management system would shut down an AC, (if all are running at the same time), if a microwave or some other type of large draw were put on the system, in order to keep breakers from popping.
Old 09-24-2014, 12:20 PM   #10
ironj's Avatar
Yes I was thinking some sort of delay timer that wouldnt allow multiple high draw items to run....I mean I am sure you could easily RUN 3 a/c on 50 amp, its the surge that is the issue. ....maybe someone will know for sure.....
