Old 02-06-2013, 01:47 PM   #1
Bikerman2's Avatar
I'm looking At the convert a 5th wheel to goseneck adapter Any one use one like this
Bikerman2 is offline   Reply With Quote
Old 02-06-2013, 01:50 PM   #2
Denver, CO
garbonz's Avatar
This what?
2017 Fuse 23T
Old 02-06-2013, 01:53 PM   #3
I assume you mean something like:
I have heard depending on the unit you can run into warranty frame issues... but don't use one so I don't know for sure.
Walter & Donna
2011 CC LB RAM 3500 CTD 6.7L DRW
2013 Cedar Creek 38FL
2017 Days Planned: 135
38FLCamper is offline   Reply With Quote
Old 02-06-2013, 01:57 PM   #4
Bikerman2's Avatar
This was the one I was looking at
Old 02-06-2013, 02:07 PM   #5
Owner/Operator
RodeoGeorge's Avatar
I've used the Colibert conversion on the last three 5th wheels that I've had, without an issue. (Carrilite, Medallion, and Weekend Warrior)
I need to retain the Gooseneck type hitch on my Hauler because of other trailers I tow. That being said, I just ordered a Rockwood 8289WS, and I'm going to install the B&W Companion 5th wheel hitch on my hauler and use the 5th wheel configuration for the new RV. Since the Companion can easily be pulled to revert to the Gooseneck Ball, I will have the best of both worlds.
RodeoGeorge
RodeoGeorge is offline   Reply With Quote
Old 02-06-2013, 02:10 PM   #6
TURBS's Avatar
Welcome to the forum!
What do you have for a 5th wheel?
Old 02-06-2013, 02:13 PM   #7
Bikerman2's Avatar
Just ordered a 30 hfs5-ep
Old 02-06-2013, 02:22 PM   #8
Fulltime family RVer
I'd never researched this myself and have never used a product like it, so take my opinion with a grain of salt.
The Internets say that fifth wheel pin boxes aren't setup/strong enough for gooseneck hookups. Cracks, breaks and general badness can be expected. That said, like above - you'll also read about people who have done it successfully for quite a while.
You may want to contact your fiver manufacturer directly regarding warranty. Again, the Internet says you'll void your frame warranty if you use one.
I use the B&W Turnover Ball gooseneck with the Companion Fifth Wheel hitch. It allows me, with relatively little work, to switch between gooseneck and fifth wheel if I so choose. I don't have a reason, but the option is there.
5th wheel
