Old 11-22-2018, 06:28 PM   #1
Air Lift Questions
I'm thinking about installing an Air Lift on my 2003 F250 to help level and correct a bit of squat/sag when towing my fully loaded Toy Hauler and full truck bed.
Does anyone have good or bad experience with them.
Thanks.
Fusefinder is offline   Reply With Quote
Old 11-22-2018, 07:13 PM   #2
Coach
I have the old fashioned manual fill type on our truck and I love them for towing. Just hate when I forget to air down when I don't have that load on. Makes the back a little firm.
Cut it 3 times and it's still too short...
2017 Sandpiper 381RBOK
2006 Ram 3500 Cummins Dually
valleyduo is offline   Reply With Quote
Old 11-22-2018, 07:32 PM   #3
rsdata's Avatar
I used Airlift 5000 (I think) it was on a 2001 Dodge Maxi-van and it cured rear end sag... I just used the stock manual air-ups run to the back bumper... a few pounds of air made all the difference with leveling.
Too much of anything is bad, but too much good whiskey is barely enough. Mark Twain
2014 Shamrock 183
Old 11-29-2018, 08:09 PM   #4
Tim Coltrain's Avatar
Air Lift Upgrade
I installed the air lift 5000 on my 2018 Duramax. It took me a while to find that perfect setting. Not sure if you are trailering or 5'er. Leveling is a good thing but remember you are leveling camper as to truck. To high causes weight to transfer to back. You got to find that perfect setting. I also added the Trailair bag system to my camper which also helped with chucking and slamming. So all in all I love both of mine. Go for it.
Tim in NC
Tim & Rita Coltrain
2012 Chevrolet 2500 Duramax Crew Cab, Allison Tranny Has now been replaced by a NEW 2018 LP5 Duramax 2500 Allison Tranny.
XLR Thunderbolt 2016
Tim Coltrain is offline   Reply With Quote
Old 11-29-2018, 08:14 PM   #5
Ive had the auto level feature and now the remote feature. The auto level was nice, didnt have to do anything. I love mine.
cmysstailights is offline   Reply With Quote
Old 11-29-2018, 08:17 PM   #6
I went ahead and bought the manual fill type, from what I've read most have run the Schrader valves to the rear, near the bumper or license plate.
My question now is: do you install a gauge with it, for a quick visual verification?
BTW I have a 2017 Grey Wolf 26RR tow behind.
Old 11-29-2018, 08:18 PM   #7
2007 WildCat 32QBBS
05CrewDually's Avatar
I have the Airlift kit on my DRW F350. The kit is bolt on and functions well. No complaints.
Just make sure you order the correct kit depending on if you have a gooseneck hitch or not.
05CrewDually is offline   Reply With Quote
Old 12-09-2018, 10:25 AM   #8
Recommend running separate lines to each bag rather than the T-type, as this helps with sway if the air pressure can't transfer between bags. I haven't seen a setup that has a gauge installed like that without running airlines to the gauges inside the cab (which adds a layer of complication to the install). A regular tire gauge that goes to 100PSI will suffice.
2011 F-350 Dually Diesel
2017 Wolfpack 325 Pack13
2014 Yamaha Super Tenere
2017 KTM 500EXC-F
blackseven is offline   Reply With Quote
Old 12-10-2018, 12:25 AM   #9
Coach
Once you know your magic number, just make it part of your tire check. Tire pressure gauge checks them just fine.
Old 12-12-2018, 01:28 AM   #10
AMG
I have the AirLift 5000's with the Wireless One compressor setup. I have had AirLift 5000's on my old truck and also Firestone bags on the truck before that. I am happy with the AirLift and absolutely happy with the compressor. Manually inflating/deflating sucks. I am too old for that crap and i am only 40.
TH : 2016 Stealth WA2916
TV : 2012 Ford F-250 PSD
AMG is offline   Reply With Quote
lift
