Old 03-08-2016, 10:00 PM   #91
Usually Confused Member
emm-dee's Avatar
Originally Posted by 05CrewDually View Post
Let the air out and go for a tow. Then you'll know the difference if you're curious.
Nope. It's doing just fine so I ain't gonna mess with it.
At some point during every day you suddenly realize nothing else productive is going to happen the rest of that day. For me, it usually occurs around 9 am.
Vengeance 25V (the Harley needed a home)
Old 03-15-2016, 05:51 PM   #92
My new truck.
http://www.forestriverforums.com/for...cture14843.jpg
2016 Vengeance 320A
2015 Chevy 2500HD LT 6.6L 4x4 ccsb Z71 trim
2012 HD Electra Glide
Andersen Ultimate Aluminum fifth wheel hitch V2
Nights camped 2015-didn't count
Nights camped 2016-43...so far
Electra glide is offline   Reply With Quote
Old 03-15-2016, 10:07 PM   #93
2007 WildCat 32QBBS
05CrewDually's Avatar
So you ride around with them filled all the time? What PSI do you keep them at?
05CrewDually is offline   Reply With Quote
Old 03-15-2016, 11:02 PM   #94
emm-dee's Avatar
Not filled all the time. Talked to AirLift about the pressures and they say the minimum pressure is 5 psi but they recommend 10 psi. I use 10 and don't notice any change in ride quality. Five psi won't quite stop the wheel hopping problem but 10 does. Before I hook up the TT I run them up to 35 psi.
Got surprised this winter a few times when I first turned on the ignition when the outside air temperature was about 20. Startled me a little when the compressor kicked on (it is a little on the loud side).
Old 03-16-2016, 12:19 AM   #95
2007 WildCat 32QBBS
Oh o.k. I thought you were riding around with them @ high pressure. That can make a rough ride, at least on mine it does. I keep them @ 5psi unless I have a load on. Even 10psi is a little jarring on my f350 dually.
Old 03-20-2016, 04:59 PM   #96
The dealer got most of my problems fixed Friday and Saturday. The couch slide and the safety recall being the biggest things. The service guy even fixed the fridge switch. He noticed it never shut off and it bothered him while he was working on the glass door. He said the switch was "stuck". I wondered why it would never shut off but when I asked on the forums I was told it was auto shut off. If you press the button it is supposed to shut off. If it doesn't he showed me the screws to remove to take the switch box off and "wiggle" the switch to get it unstuck. Overall the service guy did an awesome job in the time that he had to fix all the warranty requests I had.
This was also my first tow with the Andersen Ultimate Aluminum fifth wheel hitch. Not very difficult to hook at all. The ride was very smooth. I do want to look into a air king pin to help reduce rough road jumping on the highway. On I-80 there where a few spots where the highway was bouncy. It got very annoying and I believe a better king pin would help reduce that vibration. The really nice thing is that when I store the camper I just loosen 3 bolts then remove the hitch (32 lbs) and put it into the garage of the camper.
2016 Vengeance 320A
Old 03-25-2016, 09:27 AM   #97
Glad to hear that you got everything fixed. I had a leak in my garage/ living room ( see another thread that I started) . I believe that it is fixed now.
LB TN is offline   Reply With Quote
Old 03-25-2016, 09:51 AM   #98
LB TN I saw that. I need to look at your pictures closer (had jury duty this week) to make sure I don't have the same issue in mine.
Just curious but I noticed the exhaust on the truck is louder when I have the camper hooked up. I assume this is normal? I mainly noticed it when slowing down. When I let my foot off the gas and let the engine do the braking. It was louder, only way I can think to describe it.
Also LB TN we are planning a trip to Deals Gap. We will be coming through TN in Late July early August.
2016 Vengeance 320A
Old 03-25-2016, 11:59 AM   #99
As far as your truck to me that all sounds normal. It's what they call turbo/ exhaust braking when slowing down it should sound like a big rig, hopefully that makes sense.
Brian
04 Chevy 2500 Duramax / EFI Live Tuned
2016 Forrest River Vengeance 320a.
Old 03-25-2016, 01:40 PM   #100
Yeah that's what mine sounds like. Thanks!
2016 Vengeance 320A
