06-14-2016, 07:14 PM
#141
Nice
06-14-2016, 07:38 PM
#142
very nice!
06-15-2016, 06:14 AM
#143
Frog-Toberfest Organizer
Jealous and it looks great. Mine sits in an outside storage lot. No room at my house to even park mine. I don't like it but not real interested in moving just for the camper.
So has anyone else noticed the trim coming loose? I still need to install those extra screws but keep forgetting...since it's not at my house.
2016 Vengeance 320A
2015 Chevy 2500HD LT 6.6L 4x4 ccsb Z71 trim
2012 HD Electra Glide
Andersen Ultimate Aluminum fifth wheel hitch V2
Days camped '16=43, '17=47, '18=57 '19=47 '20=47 '21=64 '22=62 '23=72 '24=0
06-15-2016, 07:32 AM
#144
Very nice! I'm so jealous right now. I wish I had the room to build something like that for my XLR. What size is the pole barn?
2016 FR XLR Thunderbolt 395AMP
2015 Ford F350 CC SB 4x4
06-15-2016, 06:56 PM
#145
I thought I had a decent set-up. I have a large barn for my landscape equipment. But the largest door is only 12.5' tall. I have a lean-to on both sides and one side has about 13.5' of clearance down the middle. Its a little over 11' wide so the Vengeance fits in there nicely. I have greenhouse shade cloths all the way down so 90% of the sun is blocked out.
Biggest negative I have is I can't open the slides while inside. That's a bummer.
LB TN. A barn just for the camper and truck. You are now my hero.
06-16-2016, 09:23 AM
#146
Thanks for the nice comments. When my wife wanted to upgrade toyhaulers I said that this one will be covered some way shape or form. Well I figured why not over build cause we're not moving anytime soon. It is 30 wide 48 long.
06-16-2016, 09:30 AM
#147
Lol. It's a nice Man cave . Our old toyhauler was a 2008 model and I busted my butt trying to keep it looking good but as you know that the sun destroys these things. Plus I figured build big or go home. Lol. Thanks again for the nice comments.
06-22-2016, 09:34 PM
#148
Originally Posted by LB TN
Well boy's & girl's I've been off here for awhile and I wanted to share pictures of my pole barn I had built to keep the Vengeance in.I've been planning this since February and it's finally done.
That's awesome!!!
06-22-2016, 09:38 PM
#149
That is nice! Not exactly the vision I had when you said pole barn. That is the mac daddy for sure.
Steve & Paula Smith
Warner Robins, GA
New 2016 Vengeance 320A
Previously owned: 2014 Vengeance 25V, 2011 KZ 184,
2011 DIY 7 x 14 Enclosed Trailer,
Motorcycle pull behind cargo trailer with tent
#150
I was thinking about trading up to the touring. 38L12 model to be exact. The 377v has been great! The wife and I were thinking about something a little more fancy.
06-23-2016, 09:33 PM
#151
We were down to the Touring Edition 40D12, the XLR 420 and a couple of Fuzions. Very happy with our choice so far.
If you favor more room inside, go with what you're thinking. But if you like chilling outside, the 40D12 has been far better than we ever imagined. Side patios are so much better than we thought.
06-23-2016, 10:10 PM
#152
The 40D12 is pretty awesome with the side patio! We thought about it but didn't think it would benefit us. Places we go to just doesn't have room. Spot are already tight enough to with a 42 footer lol! We also thought about the 38D12 but didn't like the fact it doesn't have a aft bath.
How do you like the construction quality of the touring? Does the 6 point hydraulic jacks feel pretty stable? We have JT strong arms on our rig but still moves quite a bit when the kids are playing in the back.
06-24-2016, 06:28 AM
#153
So far, its been flawless. We've been on four trips and the only thing that has failed is one of the DVD players this past weekend. For some reason, the small Samsung Blu-Ray player just quit working. That's certainly not a Vengeance fault and we've already turned it in for a warranty claim.
The 6 point system is great. Easy and very stable. We don't do much in the back so I can't give you an honest opinion for your situation. The rear legs are close to the rear axle so you have a lot of camper hanging off back there. But for us, we've been very happy. Headed back to Ocean Lakes in August and then Disneyworld the middle of December. If I had to do it again, I certainly would.
06-27-2016, 05:55 AM
#154
What caulk would you use on the outside of camper? I finally remembered to pull a screw out of that black trim so that I could buy some more. The trim is coming loose so I am going to put more screws in it and I also need to reapply the caulk.
2016 Vengeance 320A
07-05-2016, 11:24 AM
#155
Who did I just see on I70 near St Louis?
2016 Vengeance 320A
07-05-2016, 02:54 PM
#156
Wasn't us. Ours is sitting under the shelter at home. We don't take her out again until mid-August.
07-05-2016, 04:26 PM
#157
It's the first one I have seen on the road since we bought ours. It looked really cool
2016 Vengeance 320A
07-05-2016, 04:33 PM
#158
I see them but very rarely. That's another reason I like them. Folks look at them and ask, "What kind of camper is that?" I guess the name on the cap trips them up?
Around here, its Raptors, Fuzions, Cyclones, and the occasional XLR primarily when it comes to toy haulers.
07-05-2016, 04:36 PM
#159
Bed storage lift
Just a heads up because this will probably happen to all of ours. The beam that the piston is connected to is not very secure. From what I could tell it only has one screw in each end and it twists after a while. This needs to be reinforced or the beam will twist damaging the sheet of "plywood" and possibly the pistons. I would suggest some small "L" brackets which is what I will be using on mine.
Anyone know how to disconnect that piston? I could remove it from the wood I guess? Not real sure what's easier.
2016 Vengeance 320A
07-05-2016, 11:12 PM
#160
2007 WildCat 32QBBS
Use a small screw driver under the clip and pry off the retaining clip far enough so the ball pops out of the socket.
To install just push it on.
Same goes for most automotive ones too, as seen in this picture.
