Old 05-04-2014, 03:08 PM   #1
Spartan Toy Hauler..... Looking for someone that has one or can help answer some issues on a/c
Doesn't seem to keep living area cool. Bedroom is nice tho. Any tips on what I can do to cool this thing off?
Sent from my SM-G900V using Forest River Forums mobile app
polarbear is offline   Reply With Quote
Old 05-04-2014, 06:28 PM   #2
Todouble's Avatar
Do you have airflow coming from the vents? Is it cool air? I've seen a lot of flex ducts fall off the registers or boots and blow the air in dead space. If the air is there but not cool that would indicate a problem with the ac unit itself. Compressor not starting or low refrig charge....
Todouble is offline   Reply With Quote
Old 05-04-2014, 06:32 PM   #3
There is cold air blowing thru the vents. Seems like the windows r putting off more heat then ac can keep up with. 100į outside and 78į in trailer. Won't get colder. Think I gotta do something to windows.
Old 05-04-2014, 06:35 PM   #4
Todouble's Avatar
Yeah sounds like capacity issue on the ac. One ac or two? How big is the rig? Most people opt for two acs if avail on the bigger rigs. Over 34 ft or so. When your baking in the sun the one won't keep up. My windows are tinted pretty deep but I still feel the sun heat coming thru. Mfg will tell you that there designed to only do 20 degree diff than outside ambient air. Example- If it's 95 outside then the ac can only do 75 inside.
Old 05-04-2014, 06:36 PM   #5
If it's 100 outside and 78 inside I'd say you're doing pretty good.
Don & Beverly, Chattanooga, TN
2011 Ram 1500 Quad Cab
2014 Rockwood Mini Lite 2304
2013 Rockwood Signature Ultra Lite 8310SS
Don0426 is offline   Reply With Quote
Old 05-04-2014, 06:37 PM   #6
2 ac units. 36 ft toy hauler. Just seems the ac can't keep up with outside heat. I'm gonna do something to windows. Any suggestions?
Old 05-04-2014, 06:40 PM   #7
Take a temp reading at the return vent and another at the discharge vent. There should be at least a 10 degree drop from the AC unit.
Sent from my SCH-I545 using Forest River Forums mobile app
2007 GMC 2500 Duramax Crew Cab LB
2008 5th Wheel Cardinal 36LE
R Whitlow is offline   Reply With Quote
Old 05-04-2014, 06:40 PM   #8
Todouble's Avatar
Dual pane would help a lot but a little late for that. Not even sure if that is an option but it was on my crusader. I have had some success with the smoked max air vents and you have to cover that skylight in the bathroom if you have one. That damn thing pours in the heat.
Old 05-04-2014, 06:57 PM   #9
Plain Old Member
Fit windows with reflective bubble insulation. Works wonders. I can't explain very well what we did with the AC fan discharge, but think of it like a tent shaped piece that direct air flow more efficiently to the ducts. Increased the air flow a bit. Also insulated return air box inside and out like some have done on here. Used the same reflective bubble insulation and used spray adhesive to attach.
John and Rebecca Dickson
Emma-7 / Little John-5 / Iva-1
Full Timing Again, Rev B
2013 Ford F-350 Lariat CC LB PSD
2015 SOB TT - With OC's Awning Poles (#8)
At least in Heaven, RVs will be perfect, and I won't have to keep fixing them.
BigJohnD is offline   Reply With Quote
Old 05-04-2014, 07:00 PM   #10
