Old 04-12-2015, 10:07 AM   #1
northstar1960's Avatar
Awning adjustment
When extended the awning sits straight out . how do you lower the front so it sheds water away from unit ? tried to move it but did not seem to want to go and did not want to break anything . the lock nuts were loose and maybe it was just the pressure from the lifts assist
northstar1960 is offline   Reply With Quote
Old 04-12-2015, 12:13 PM   #2
Make? Model? Photos?
breezyhillfarm is offline   Reply With Quote
Old 04-12-2015, 12:36 PM   #3
Call (Jeff Couch) your Dealer and ask! Youroo!!
Old 04-12-2015, 12:57 PM   #4
It's the domectic brand . on the 29 xlr 20' long powered. not sure the model of the unit . i think the gas charged lifts caused me not to put to much pressure on it for fear of breaking . i will check it out again tomorrow when i head out to where i haveit parked for now
Old 04-12-2015, 12:58 PM   #5
you're a funny one . i'm going to call Jeff Couch soon but it will be for another matter all together
Old 04-12-2015, 01:09 PM   #6
bubbles's Avatar
Pull the arms down (compresses the strut) to where you want them and lock the bars in position with the wing nuts. Sometimes easier to reach if you make the adjustment with the awning slightly extended due to height. Be sure to loosen the wing nuts before retracting fully to stow position. Sometimes a good idea to lower one side slightly if expecting rain. I know there is an auto dump feature and it has always worked for us but you never know.
Old 04-12-2015, 01:37 PM   #7
Thanks Bubbles . that's what i thought needed to be done but did not want to exert to much force until i knew for sure.
Old 04-12-2015, 02:03 PM   #8
Brother Les's Avatar
The awnings are made to self dump. With the lock nuts loose, the weight of the water will lower the lift assist on one side or the other and 'dump' the water and then return to the normal height. To continually let the rain water flow off one side or the other, pull one side down and tighten up the lock nut, but make absolutely sure that the lock nut is loose and the awning is back to normal height when rolling it up or damage my hallpen.
Brother Les
Old 04-12-2015, 07:12 PM   #9
Canadian Member
itat's Avatar
The first half of this video will be helpful.
2011 Rockwood Signature Ultra Lite 8293SS, 12K Equal-i-zer WDH
2009 Ford F-150 XLT SuperCrew, 5.4L, 5'6" bed (2012 - 2016)
itat is online now   Reply With Quote
Old 04-12-2015, 08:20 PM   #10
Thanks just the info i needed . I'll check it in the am and run through operation
awning
