Old 02-26-2017, 09:46 AM   #1
Bedding for cargo beds
What size bedding is everyone using for the bunks in the cargo area? They seem almost as wide as a king bed but they are longer then a king. Is there anyone out there that makes something specific for them?
drvitlkustolit is offline   Reply With Quote
Old 03-01-2017, 01:55 PM   #2
imaXLRowner's Avatar
XLR double bunks in rear that go into the ceiling.
I found that my upper bed was not stiff enough for a full size person. So I cut a pec of plywood and set it in under the mattress. Next we perched a 4" memory foam king size and cut to size. On the bottom coach/bed I just have the memory foam because we convert back and forth to a coach. The top bunk is the best and the bottom bunk isn't bad.
No complaints on sleeping with this setup.
Hope this helps
imaXLRowner is offline   Reply With Quote
bed, beds
