Old 01-26-2019, 12:55 PM   #1
Cable input
Which of these is cable and which one is satellite?
I am a nube with no manual.
2012 xlr
Maineman is offline   Reply With Quote
Old 01-26-2019, 01:18 PM   #2
brookstone345sa's Avatar
You will have to try both. Remember to turn off antenna booster when on cable. Mine were not marked correctly
brookstone345sa is offline   Reply With Quote
Old 01-26-2019, 01:28 PM   #3
Just as confused as you
Scrapper's Avatar
Welcome to the forums. Sorry, I can't help you with the connections.
The manual from Forest River is generic and will not tell you which connection is which. If you don't have any manuals from the manufacturers of the individual accessories you will need to get the make and model numbers from each and look them up online. There are manuals for many of the appliances in the Library section of these forums.
Richard & Jill
Camping since 1989, seasonal since 2000
The Faster I Go, The Behinder I Get.
Old 01-27-2019, 01:13 AM   #4
AMG
Even with my antenna booster off I couldn't get good signal with my Wally receiver and Tailgater dish. I ended up running a 2nd coax RG6 that is only for the receiver/dish. Good luck
TH : 2016 Stealth WA2916
TV : 2012 Ford F-250 PSD
AMG is offline   Reply With Quote
Old 01-27-2019, 06:25 AM   #5
"On the road again"
rjshiflet's Avatar
Send a message via AIM to rjshiflet
Our most recent TWO Forest River products...(Columbus and Cardinal) which we love very much...both had to be rewired. The Columbus had to have 100% of the coax from the web bay to the main TV redone (at Forest River's expense). There were a half-dozen or more "connectors" in that 30' run of wire. Why? I have no idea, when one single strand would have been much cheaper and faster for the factory.
The Cardinal...I discovered the problem and simply switched the wires connected to the coaxial inputs behind the wet bay and it corrected the problem.
Robert & Estha Shiflet
Cardinal 3456RLX - '17 Ford F350 Lariat Ultimate - DRW w/B&W OEM Companion hitch
Nights Camping 2012 & 2013 & 2014 & 2015 & 2016 & 2017 & 2018: 834 ~ Nights Camping 2019: 118
rjshiflet is offline   Reply With Quote
cable
