oh boy, vet rv'er here and I have a list. the kitchen sink doesn't drain because when the slide is out the 1.5 flex hose is bent in half so after mom does the dishes I have to slide in to drain the sink haha! master sink p-trap is cracked. water pump vibrates the walls and I cant find it to fix it! sounds like its behind the toilet and inside wall but no access at all? the heater blows a mere warm through the floor vents and all the heat is roaring out the exhaust. I removed the intake grate and heater rear cover then my rv heated up in 5 minutes. parts on order.......
