Old 03-01-2014, 08:43 PM   #1
jonnys_walkers's Avatar
Fuel cell and components in a toyhauler
We have a toyhauler and we are planning an extended vacation to Arizona for some dry camping.
We would like to take advantage of the capacity of the fuel cell. I have never put fuel in the tank. Because we tow with a diesel I would like to use it for diesel fuel.
The labeling by the filler cap states Gasoline Only.
In researching inline filters I found there is a difference in the gasoline filters to the diesel filters.
This raises a very important question, are the components suitable for diesel fuel?
Example hoses and pump internal parts.
Has anyone used diesel in their toyhauler fuel tanks?
Thanks in advance.
John
jonnys_walkers is offline   Reply With Quote
Old 03-01-2014, 09:25 PM   #2
Ford Idaho's Avatar
My guess is the tank pump filter and hoses have all been built to the minimum standards to handle gas I would not put diesel in there.
Old 03-04-2014, 10:52 PM   #3
jjgabe's Avatar
Do you plan on running a generator? If so You may harm the generator running on diesel. Putting diesel in the tank would contaminate it and limit resale down the road.
jjgabe is offline   Reply With Quote
Old 03-16-2014, 08:15 AM   #4
Brentw's Avatar
As others have mentioned, do you have an onboard generator- if so then no go (assuming you have only 1 fuel tank). If not, I would not give it a second thought. Every fuel transfer pump and hose I have encountered are petroleum rated- not gasoline or diesel. Should you wish to return to gas, run her empty, fill up with gas. the residual diesel in those small quantities will not harm a gas engine.
Brentw is offline   Reply With Quote
Old 04-07-2014, 08:55 PM   #5
Solar panels work well in az
woodtick is offline   Reply With Quote
Old 04-10-2014, 07:05 PM   #6
We he said.
2007 Work & Play 34RL Toyhauler.
2003 GMC Sierra HD Dmax Alli.
036.6turbo is offline   Reply With Quote
