Old 05-21-2012, 08:39 PM   #1
fuel station problem - Sierra
We just bought a used 2006 Sierra Sport toyhauler.Put some gas in the fuel station to try it out. When we purchased we were told we had to turn on two switches, one inside and one outside. Turned on the inside one and then, what we thought was the outside one. When we looked more closely it was the emergency shut off. Now we have no power at all. Lights on inside switch are dark and pump doesn't make any noise at all. Is there a reset somewhere? And is there actually a second switch outside somewhere or were we told wrong?
epodjn is offline   Reply With Quote
Old 05-21-2012, 11:18 PM   #2
TURBS's Avatar
I think the inside switch allows you to use the outside switch .
inside has to be on to be able to turn it on outside .
kind of a gas theft deterrent if you will.
I would double check with your dealer to unsure proper use of switches .
Old 09-19-2012, 12:01 PM   #3
I have a 2005 Sierra Sport toyhauler. To use my fuel station, I turn on the inside switch first (the light comes on- in the switch). Then go outside, position the fuel handle, then pull the outside switch and then the pump turns on and I dispence gas. My guess (armchair troublshooting) is the power to the inside switch is not there - possible a fuse blown, wire issue. I have not seen a reset switch, but I have not looked that hard for one wither.
dagusty is offline   Reply With Quote
Old 09-21-2012, 02:31 PM   #4
WFObansheeboy's Avatar
I have a 2004 Sierra Sport toy hauler. To use my fuel station, I turn on the inside switch first (the light comes on- in the switch). Then go outside, position the fuel handle, then pull out on the outside switch and then the pump turns on. I think the two switches work's to cut down on gas theft. Sound like a bad pump or a bad switch. let us know what you find.
Toy Hauler 04 Sierra 5th wheel,What's in the garage.
MY ride 92 Yamaha Banshee,Wife ride 08 Honda TRX250EX
06 F250 6.0L 5R110W 4X4
FabTech 8" lift W/dirt logic 4.0 Front & 2.5 rear
Rolling on 38X13.5X18
4.56 W/ARB air locker front & rear
WFObansheeboy is offline   Reply With Quote
sierra, problem
