Hello,
My 2017 Fury 2910 had the fresh water tank squeeze out the bottom of the trailer.....the weight of the tank full of water started to sag and it broke the self tapers holding the X-brace flat bars.....the tank then bellied out from between the small angle iron and landed in the plastic under belly sheet.....this is all that held the tank up.....I patched and reinstalled the tank but the flat bar is flimsy and cannot support the 700lbs of water on rough roads....I installed a 3" channel iron cross brace from frame rail to frame rail on a slight angle to avoid the weight In the tank from resting on the drain valve attached to the tank......I am going to install another brace where the black and grey tanks are located to avoid any future problems
