Old 01-29-2016, 01:40 PM   #1
Generator
I know I need to start gen. every so often but, can you do it safely while being plugged into shore power. Thanks ahead for your feedback
Happy Dave is offline   Reply With Quote
Old 01-29-2016, 02:04 PM   #2
Not familiar with your setup but in most instances the answer is yes. Assuming you have an on board generator factory wired, you may have an automatic transfer switch with the generator as the primary power source. When you start the generator it should switch from shower power to generator power with little to no interruption. There are also manual transfer switches, in which case you would continue running on shore power until you manually switch.
2015 Work and Play 30WRS
2005 Dodge Ram 2500 4x4 diesel
wildbill79 is offline   Reply With Quote
Old 01-29-2016, 09:32 PM   #3
2014 XLR 27HFS
dave961's Avatar
I do not do that. It's one or the other for me.
Dave & Audrey
dave961 is offline   Reply With Quote
Old 01-30-2016, 12:18 AM   #4
Play Harder's Avatar
A little more info needed - what gen set? Factory wired? I know on mine 4k onen - there is also a circuit breaker on the gen and in most generator just flip the breaker off if concerned about burning something up
Get out and Play Harder😛
2016 XLR Hyper Lite 29hsf - loaded picked up 3-24-2015😊
2008 Can Am Spyder
Kite Boarding is my Addiction - GOT WIND!
Play Harder is offline   Reply With Quote
Old 01-30-2016, 03:29 AM   #5
SKnight's Avatar
Why not just walk around and pull the plug?
And don't forget, it's recommended to load the generator while you exercise it. I plug in a space heater set on high to load it some.
generator
