10-23-2017, 10:39 PM
Getting Rid Of A Smell
My 2013 Puma has a faint smell sort of like burnt bacon.
I wonder is this is coming from the rubber floor in the garage?
Any ideas on how to get rid of it?
I have tried sprays, scrubbed the floor with simple green and mopped with Dawn.
2011 GMC Duramax/Allison
2013 Puma 356QLB
Days Camped 33
Miles 6450
10-23-2017, 11:01 PM
I have found zeolite crystals can get rid of any odor I have sent its way.... mold from my old tt and gasoline (generator leaked) from the basement of my fiver. These are rechargeable by simply setting them in the sun for 6 hours.
Not sure what the odor is from other than have you cooked bacon in the trailer? That smell can linger and rubber can absorb odors pretty easily. We always cook bacon on the grill outside for that reason.
2014 Sabre 34REQS-6
10-23-2017, 11:14 PM
Not sure what the door is from other than have you cooked bacon in the trailer? That smell can linger and rubber can absorb odors pretty easily. We always cook bacon on the grill outside for that reason.
Thanks asquared
That looks like a good thing, I have never seen that before.
I know the PO hauled dirt bikes in it and it looks like that there are stains all over the rubber floor, when I scrubbed the floor with a stiff brush and simple green I got about 75% of the spot cleaned up.
2013 Puma 356QLB
Days Camped 33
Miles 6450
10-24-2017, 12:19 AM
Ozone generator may help. There's risks, so read up and don't have any pets or people or anything living in the coach. But I know people who have great success with them removing odors.
TH : 2016 Stealth WA2916
TV : 2012 Ford F-250 PSD
10-24-2017, 06:15 AM
Thanks AMG, my concern with a Ozone generator is it interaction with plastic and rubber products. As my 5er would probably be a lower quality products it is full of plastic parts and then there is the 12' x 7' rubber floor in the garage.
I will have to do some more reading up on it though.
2013 Puma 356QLB
Days Camped 33
Miles 6450
10-24-2017, 06:48 AM
Tinkerer and Putterer
vinegar soaked paper towel in an open plastic container is my go to for permanent killing of off gas smells like you're describing. Smell should be gone within 24 hours. Works great on cat boxes too. Only reason for using the paper towel instead of an open container of vinegar is less mess when I accidentally knock it over.
10-24-2017, 06:58 AM
Thanks HappyGuy, I can try this before I take off Sunday morning for a weeks trip.
2013 Puma 356QLB
Days Camped 33
Miles 6450
10-24-2017, 03:51 PM
cotton balls soaked in wintergreen on a paper plate placed in a couple of areas will remove a lot of smells, but, then you must get the wintergreen smell out  You can do that with open windows. Hope this is some help.
Retired Auto body teacher/Retired RV Dealer GM
2017 Puma 255RKS
2019 F-250 Lariat Super Crew 6.2
No Kids
No Pets
But lots of Fun traveling with my wife
10-24-2017, 04:58 PM
"LOL" well I am already used to having the doors open and fan going
2013 Puma 356QLB
Days Camped 33
Miles 6450
10-24-2017, 06:27 PM
We take smells out of sea containers with coffee grounds dry
10-24-2017, 06:36 PM
Thanks festis and welcome to the forum.
do you just spread them around on the floor?
at least coffee does smell good
2013 Puma 356QLB
Days Camped 33
Miles 6450
10-24-2017, 07:33 PM
We too have had luck with coffee grounds. I just put out a couple of tin foil pie pans. Good luck!
Phil, Heather & Olaf the Boxer
Ontario Canada
Lexington 283GTS
Just spread out on the floor close it up next day sweep it out or blow it out
10-24-2017, 08:59 PM
Thanks guys, I do have some coffee that is getting a bit old
2013 Puma 356QLB
Days Camped 33
Miles 6450
10-25-2017, 10:54 AM
Auto Deoderizer
Try chlorine dioxide. You can get it on Amazon in several brands. I used Star Brite Auto Odor Eliminator -$13 and change. It does leave a slightly "swimming pool" scent but it wiped out a persistent nasty tobacco smell from my car. They claim it is safe to use, but like ozone I felt better airing things out before sitting in the car.
10-25-2017, 02:26 PM
Thanks LairdT, I have some pie pans of vinegar in it right now but if that does not work I will add this to my list of things to tray.
2013 Puma 356QLB
Days Camped 33
Miles 6450
