Old 08-19-2014, 02:56 AM   #1
iowa2284's Avatar
Gray Wolf 25RR 2015
Just bought my first toy hauler the first time out I was unloading my harley and something on the bottom hit the diamond plate. Now I need to put in a new plate. Does anyone know is it just the top screws holding it in place? And does anyone have any good tips on unloading a bike from the 25RR the ramp is very steep already dropped my bike once and don't want that to happen again. Thanks for any help.
iowa2284 is offline   Reply With Quote
Old 08-19-2014, 05:21 PM   #2
stealthWA2313's Avatar
I am certainly no expert, or even have any experience in loading a street bike into a toy hauler but have seen people use ramp extensions similar to this.
The Big Boy II Motorcycle Ramp System
'17 F350 STX 6.7 CCSB
'15 Stealth 2313
stealthWA2313 is offline   Reply With Quote
Old 08-20-2014, 06:58 AM   #3
I have a 31 foot Puma and load a Road King into it. Sometimes the frame hits but I have never had a damage you described. Try changing your angle of the ramp door when your loading. The more steep the angle the more likely you will scrape the frame or damage the ramp or bike.
set182 is offline   Reply With Quote
Old 08-20-2014, 10:36 AM   #4
iowa2284's Avatar
Thank you for your help
Old 09-01-2014, 07:20 AM   #5
BeeGee's Avatar
I have loaded using a ramp extension and that makes it very easy. But it is a pain to set up and dismantle. Lately i have been able to load and unload by going very slow up the ramp and then putting both feet down to take your weight off the bike as you cross the diamond plate.
2012 Ford Lariat F-350 Super Duty
2014 Forest River Cherokee Wolf Pack 27 TH
BeeGee is offline   Reply With Quote
Old 09-18-2014, 10:01 AM   #6
2014 XLR 27HFS
Gray Wolf 25RR 2015
When my ramp is too steep and the bottom of the bike hits, I have a set of (heavy duty plastic) ramps like you would drive your car onto. I put these under the back of the ramp right next to each other in the middle. This lifts the back of the ramp up 12 inches and solves my problem most of the time.
Dave & Audrey
dave961 is offline   Reply With Quote
Old 09-21-2014, 10:06 AM   #7
We have a golf cart that was doing the same thing we use our blocks we put under out feet on the trailer when we load and unload seams to work good and were not hauling anything extra with us
Nethers is offline   Reply With Quote
Old 09-22-2014, 03:21 PM   #8
4x4 post at least 2/3rds of the width of the door to place under the top lip at the ground and voila.
rblack22 is offline   Reply With Quote
