Originally Posted by Powerman
Anything with 2 axles and brakes has a 2 5/16" ball. So I've been told.
I respectively disagree. I'm currently dragging an SOB that is 19' ultralight with dual axles and dual brakes with a 2" factory hitch. The only way to know for sure is to contact the factory, a dealer with one in stock, or someone with the same model. A general rule of thumb would be as you approach the 8000lb gvwr mark, you will generally see the switch to 2 5/16" as 8000lb is the max on a 2" ball.
