How much does the ramp door playpen weigh?
Hi, I am looking at a 2019 Shockwave T28RQDX and the dry weight is 8,699 lbs. The Ramp Door Playpen is included with this rig. Most of the other models I looked at are in the 8,400 range (including Stealth and Sandstorm since they are all built on the same assembly line). The other item this particular unit has is the 1,500 watt Go Power inverter.
Between these two items can it really weigh 300 lbs more?
Forest River now includes Full fresh water tanks (150 gallons for the fresh water tank plus another 10 gallons for the water heater) when calculating the carrying capacity so the capacity is listed as 2,035 lbs.
This camper's GVWR is 12,100 lbs.
Thank you for any help.
2012 Ram 3500 Megacab SRW 6.7L Cummins
